Right brake light inoperative
Old Feb 15, 2023 | 12:12 AM
svraka's Avatar
C300///CLA250////ML350
I have 2011 Mercedes ML350 with right side brake light inoperative bulb is ok
Old Feb 15, 2023 | 03:26 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Search this forum for 'Rear Sam' problems. You need to offer up more information. Just the brake light doesn't work? All other electric functions work? Any water ingress or accidents? Have you scanned it?
Old Feb 27, 2023 | 02:15 PM
svraka's Avatar
No I haven’t scanned yet no water only Right rear brake light is not working everything is working fine
Old Feb 27, 2023 | 10:53 PM
S70Houston's Avatar
2018 GLC300 4Matic; 2008 ML550 4Matic; 2004 C320
Bulb is ok by looking at it? Or you put a brand new bulb in?
Sometimes a bulb does “look ok”, but in reality might no longer be ok.
Old Feb 28, 2023 | 07:25 AM
svraka's Avatar
Yeah I swapped out bulbs left and right bulbs it’s working fine on the left side
Old Feb 28, 2023 | 09:53 AM
ElementaryDW's Avatar
Searching....
I had a similar problem. The plastic bulb mount got fried with age and melts down a bit causing inconsistent contact. Swapped it out and it was good to go. It was for me at least. You could try that
Old Mar 1, 2023 | 07:19 AM
svraka's Avatar
Thank you everyone I solved the problem it was broken wire
