Getting oil cooler seals replaced: should I do the oil cooler at the same time?
Old Apr 27, 2023 | 06:55 PM
RhythmMachine's Avatar
2009 ML320 Bluetec
The car is in the shop now for the Bluetec Field Measures, and they confirmed that my oil cooler seals are leaking and need to be replaced. Should I have the oil cooler itself replaced at the same time, or just have them check and see if it's still in spec or not? It seems if there's almost any risk of it developing problems down the road, I may as well just pay for the new part while everything is already taken apart.
Old May 22, 2023 | 04:56 PM
2009 ML320 Bluetec
Just closing the loop on this: the dealership said there would be no benefit to replacing the oil cooler, so I just did the seals. Time will tell....
Old May 23, 2023 | 06:56 AM
DLB_Adelaide's Avatar
GL320 X164 OM642 722.902
Don’t read much on the cooler itself failing. So dealership probably saved you some $$
