ac no cool
Old May 14, 2023 | 04:13 PM
thewhitegorilla's Avatar
2010 ml350
ac no cool
Hello everyone!
I have a 2010 ml350. the ac worked great last year but hasn't cooled at all this summer. Im familiar with this type work, but it seems I may have a clutches model as the center of the clutch hub never stops rotating. is there a way to tell and what could be the problem? older clutched systems when the clutch pulls in iff the compressor is ok and you have refrigerant and air flow you have cooling, Im not up to par on the workings of this type design. can anyone explain it to me or point me in the right direction?
Charles
Old May 16, 2023 | 06:05 PM
DLB_Adelaide's Avatar
GL320 X164 OM642 722.902
Originally Posted by thewhitegorilla
Hello everyone!
Charles
When you mentioned you are familiar with this type of work, what does that mean?
I haven't looked into the HVAC system but this 'might' have a variable displacement compressor??
Owning HVAC gauges are cheap and there are plenty of internet resources for simple diagnosis on the HVAC.
Old May 17, 2023 | 06:29 AM
grkmspr's Avatar
ML350 - 2007 164.186
Check your AC Clutch;
My problem was that when I bought the car, the air conditioner worked at first, then stopped working when the car accelerated. (No fault code, new freon)
then the clutch of the air conditioner compressor broke, its parts flew away and it did not cool at all.
I bought a new clutch kit and now it always cools. https://www.autodoc.co.uk/nrf/12875379
edit:
My problem persists. The car cools well when it first starts, but after a while the air conditioner starts to stop working.
