Run Flat Indicator Inoperative? TPMS
Yesterday, my wife's tire exploded and she drove 2.5km on the flat tire.
As a result, the tire was too bad to be repaired and used again.
The problem was that the vehicle did not give a flat tire warning. It always says "run flat indicator inoperative" on the screen.
From the chassis number of the car, from option codes
There are 477 TIRE PRESSURE LOSS WARNER is available.
There are no ESP errors in the car. There is no sensors on wheels.
Why is it not working? can you help me? How can i activate? i have xentry? may be turned off before (because light didnt shown)?
Your wife should have noticed that and not continued to drive.
Furthermore, I question as to how an “exploded” tire could ever be fixed?
While my wife was turning, her tire hit the curb. (what she always does
)this time the tire sidewall cut, and she didn't notice. (women's -.-)
As for the repair issue;If the tire sidewall is cutted, they melt the tire with a special iron and paste a new rubber. If it is punctured, methods (1) Simple Plugging, (2) Patching and (3) Plug/Patch Combination.
Also, there are no sensors in the tires, there is a warning with the information coming from the esp/abs system, it is activated with xentry. I activated the system, I will try it tomorrow and I will share how it is done step by step. screenshots on another computer.
Connect car with Xentry, Control Units > Chassis > ESP > Control Unit Adaptations > Tire Pressure Loss Warning (Activating) > F12 > F4 > F2
Then i reset tire pressures with instrument cluster.
My car have not tire pressure warning light
When tire pressure is incorrect, instrument panel turns RED and says Check Tires
F12- Reactivate
F4 - On
