2006 ML350 front seats malfunction
Bought another money pit Mercedes. 2006 ML350 with timing chain slipped so had to swap another engine into it.
BUT have an issue I can't find the reason. Both seats are not moving. Car came with dead battery with the pass seat all the way to the front.
Checked fuses I think 27-28 (30amp) in the trunk and they are all good. Checked the K relay - Ok! G connection 21 pin (red and blue) 12V with key off the car. Fuses for rear SAMs in the battery compartment - Ok. Rear wiper is moving.
WHY? Need your help guys!
___
Another issues:
Scanned the car with ZURICH ZR11S:
ABS module gives me following error codes:
5420 - Fault or disturbance in can message from control unit N15/3 (ETC[EGS] Control Unit)
5026 - No can message was received from control unit transmission control
7220 - No can message was received from control unit N15/3 (ETC[EGS] Control Unit)
5399 - Can signal "gear selected" from control unit N15/3 (ETC[EGS] Control unit) is implausible
6001 - The supply voltage of the control unit is too low (undervoltage)
5752
5024 - One or more signals sent from control unit engine management via the can bus is implausible
Anything to worry about?
Thank you guys for your help!
