P2135, 5034 Fault Codes / Pedal Accelator
ML350 - 2007 164.186
Hello,
I've been having the P2135 fault for a while, the check lamp is on. It stutters occasionally, knocks at 10km/h while stationary, but I was suspicious of the differential and gear.
When I looked at the P2135 fault, they were writing to perform gear pedal reset, I did, the knocks decreased significantly.
Then, while i was thinking that the error was fixed in the car, car lit the check lamp again.
sometimes check lamp turns off by itself.
today, on the way to work, the car first revved in seconds while it was going at a constant speed on its own.
Then I went to the main road at 100km speed, I kicked down and when I touched the kickdown, the car gave an ESP malfunction and switched to LIMP mode, the accelerator pedal did not react, so when I stepped on the gas, it did not go above 2000rpm.
When I turned the car off and on, it went away.
When I looked at the fault codes afterwards, there were the following faults.
0160, 0168, 1061 always appeared, this time it was registered at 0164.
And in ESP Block, fault 5024 appeared.
Has anyone had it before? Is the problem in the accelerator pedal? I had done the P2135 tests with XENTRY before and it came out without any problems.
today i think pedal accerelator is broken but its very expensive or maybe throttle valve is broken but i dont know how can i understand the problem.
