Best Bluetooth Music/Apple CarPlay Options for W164
Old Oct 2, 2023 | 09:55 AM
5hundo's Avatar
2008 ML320 CDI
Hey everyone!
We have a Scoshe bluetooth music adapter and I knew when I bought it that it was a cheaper option. I want to upgrade to something a bit better. What do you guys use? I'm looking for something that is pretty nice, and easy to use.
Thanks for your help!
Old Oct 3, 2023 | 12:09 PM
EWT's Avatar
EWT
11 ML550, 95 Supra TT, 14 Audi S4
Originally Posted by 5hundo
Hey everyone!
The best option IMO is to get an installation kit:
https://www.amazon.com/Teclink-Mercedes-2008-2009-2008-2011-CLK-Class/dp/B094Y8J6DT/ref=sr_1_4?crid=2DHZHD6SQ2MLY&keywords=x164%2Bstereo%2Badapter&qid=1696348689&sprefix=x164%2Bstereo%2Badapter%2Caps%2C166&sr=8-4&ufe=app_do%3Aamzn1.fos.18630bbb-fcbb-42f8-9767-857e17e03685&th=1 https://www.amazon.com/Teclink-Mercedes-2008-2009-2008-2011-CLK-Class/dp/B094Y8J6DT/ref=sr_1_4?crid=2DHZHD6SQ2MLY&keywords=x164%2Bstereo%2Badapter&qid=1696348689&sprefix=x164%2Bstereo%2Badapter%2Caps%2C166&sr=8-4&ufe=app_do%3Aamzn1.fos.18630bbb-fcbb-42f8-9767-857e17e03685&th=1
and a double DIN Pioneer/Kenwood/Sony etc. head unit of your choice. You'll also need an adapter to convert the analog signal from the RCA head unit output to optical signals like this:
The end result looks like it came that way from the factory, and you'll get a head unit with Android Auto/Car Play, Waze/Google maps, and bluetooth. (Picture is from my GL, now installed in my ML). You can also use a double din Android headunit, which are often cheaper and allow you to run android apps, but the hassle factor will be higher and the reliability will be lower.
Old May 2, 2025 | 12:08 PM
5hundo's Avatar
2008 ML320 CDI
Thanks for responding!
Of the aftermarket systems you've suggested, which are compatible with the existing backup camera, etc.? I'm going to be doing this myself, so I want to make it as easy as possible on myself.
Old May 2, 2025 | 02:16 PM
OUZO Power's Avatar
JGC SRT, ML 550, GLB 250
Funny. Our ML550 is in the shop right now getting the AVIN system installed. Will report back in a week with my thoughts.
Old May 2, 2025 | 05:34 PM
EWT's Avatar
EWT
I'm a little fuzzy on details because it was several years ago when I installed it, but I did use the factory backup camera on both my former 08 GL and my 11 ML. The 08 had the earlier (I forget the year cutoff - 09?) Command unit which has the camera wire is part of a wiring harness, and you have to cut the wire solder a RCA plug onto the wire to plug into it the new head unit. If it is a later unit(10+?), the wire plugs into the command unit and a Fakra to RCA adapter will do the trick. Everything else is plug and play. I don't think the MOST/steering wheel adapter i used is still available, but other ones like this:
Amazon Amazon
are still sold.
Old May 28, 2025 | 05:26 PM
WOT48's Avatar
2010 ML350 4Matic
I got one of those 9in Android screens from Amazon, works great for CarPlay.
