Hello, The Door Lock Cylinder is damaged on My W164 2009, I am going to replace it, the question is the following: Does the IR sensor module need to be moved to a new socket Or should I install the secondary lock that comes with it ( IR sensor) without disassembling it and it will work? Does it require any coding?
