ESP System: CAN BUS OFF
Old Jan 12, 2024 | 03:23 AM
Freeman2020's Avatar
W164
Exclamation ESP System: CAN BUS OFF
Hello ML 350, W164 2009
scanned with two different device and same DTC Codes on ESP system:
BTW on instrument cluster dashboard everything is OK no ESP light.
After clearing and than testing , Then DTC codes appears again.
Old Jan 21, 2024 | 08:01 PM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
What codes are you getting and what are the symptoms? ESP codes get triggered from everything from a faulty or intermittent speed sensor to a faulty brake light switch. If you provide the codes people can assist you.
Old Jan 22, 2024 | 12:47 AM
W164
Hello i checked and researched it, i have EIS/EZS module problem. and It is likely i think, to cause a problem with the network in general.
Old Jan 22, 2024 | 03:28 AM
BlackML550's Avatar
Does your car start everytime you turn the key?
