Please help , I have ML 550 that someone replaced the conductor plate !
Old Feb 6, 2024 | 11:48 PM
globalauto's Avatar
s320
And now after 70 mph it goes into limp mode ..
its 2011 ML 550 4matic … the car came to me after the first shop replaced the conductor plate !
I have graphed all abs sensors , and the speed sensor and there is no erratic signal showing …
No abs codes only other code is Dme code showing the speed sensor telling the TCM implausible signal ! I will
post this next ! The car only has 44k miles on it , t there is no slipping or feeling of transmission pressure making the clutch packs slip! Not until u hit 70mph the car goes straight to that PO730
I think we either have a defective conductor plate or bad programming…, thank u so much
Old Feb 6, 2024 | 11:57 PM
globalauto's Avatar
s320
Old Feb 8, 2024 | 04:56 PM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
This could be an old fashioned diagnosis rather than an electrical one. Check and make sure all your drive shafts/unis are in good health. It could be a vibration at speed that throws out the equation between speed sesnors and the transmission. A long shot, but you never know.
Have you viewed live data at 70mph when the problem occurs? Speed sensors can create ******* problems but are easy fixes and relatively cheap.
Old Apr 20, 2024 | 01:51 PM
vesiadog's Avatar
1998 SL500,2011 GL550,2009 ML350,past 1995 E320 Cabrio ,2005 ML500,2006 ML500,1996 SL500,1972 280SEL
fixed?
sounds like erratic sensors on the conductor board??
