Value Block replacement
Old Aug 4, 2024 | 09:51 PM
sinclairjdavid's Avatar
ML350 CDI W164 2010
Hi everyone. It's my first post. I have a ML350 W164 (2010). I have noticed that my front air shocks drop after use. It's not happening all the time but I'm thinking it my be a leak in the Air value block. I dont think the the two fron air struts would fail at exactly the same time. I've run a scanner on the car and there are not error codes on the compressor. I'm about to try the soap water trick to see if I can locate the leak. Any suggestions where I could be a good quality after market Air value block if I need to replace? Thxs
Old Aug 5, 2024 | 01:51 PM
imtheking's Avatar
Former R230, W220 and W221 owner
Get it from FCP Euro- $190- brand is RAPA which is OE
https://www.fcpeuro.com/products/mer...ier-2123200358
Do not use a cheap aftermarket block or you wil be revisiting the same issue again
Old Aug 5, 2024 | 06:32 PM
vesiadog's Avatar
1998 SL500,2011 GL550,2009 ML350,past 1995 E320 Cabrio ,2005 ML500,2006 ML500,1996 SL500,1972 280SEL
Rapa
Totally agree shop for the best price on Rapa
Old Aug 6, 2024 | 12:50 AM
ML350 CDI W164 2010
Thanks everyone.
Old Aug 6, 2024 | 01:43 PM
serb's Avatar
2017 GLS 450,Bmw Z4 35i
solved it with new struts,only replaced one but other one failed too in couple months
Old Aug 7, 2024 | 11:23 AM
imtheking's Avatar
always do struts in pairs (unless you're financially strapped)
Old Aug 19, 2024 | 11:56 PM
ML350 CDI W164 2010
Hi everyone. new value block in - problem still happened. Looks like new strut time. Can anyone recommend a good OE or aftermarket brand?
Old Aug 20, 2024 | 10:12 AM
rapidoxidation's Avatar
2013 ML350 Bluetec
Can't go wrong with Bilstein. Once you know the correct part number you can shop the net for the best deal. If you plan to keep the car for a hand-me-down, FCPEuro does have their lifetime warranty on their parts. Not sure if they carry Bilstein shocks but I'd be kind of surprised if they don't.
Old Aug 20, 2024 | 11:23 AM
vesiadog's Avatar
struts
I found Bilsteins on RockAuto to be the best price. Also make sure you find a 5% code .
Old Aug 20, 2024 | 12:45 PM
imtheking's Avatar
2010 ML with Air Shocks? Go Arnott. $150 on Rockauto.
I have the regular springs and went with FCS struts in the front. no issues. i had FCS on my BMW 325I and again, rode nice and smooth
Old Aug 20, 2024 | 02:06 PM
vesiadog's Avatar
arnott bags
If you go with replacement front bags… take your time and clean everything before putting the bags on.. If you are going to keep the car for 75-100k miles more but the Bilsteins. I have done many sets and won’t change just airbags anymore if I plan on keeping the car… Why.. the struts are usually pretty wore out by the time they are leaking air.
