2009 ML350 Sunroof lining / Water ???
Old Aug 12, 2024 | 03:02 AM
Carbonlord's Avatar
Thanks for any help. I noticed on the sunroof that this lining is coming off, started a few months ago. What is it, should I replace it? Recently I have had water leak in the trunk right around the center of the trunk vinyl horizontal partition cover. Th headliner has bee sagging for a year and needs to be replaced but i don't think it has anything to do with the water issue. and then thin felt lining doesn't look like it would be the culprit? Any suggestions TY
I have another post with an engine question and tires question and din't want too much in this one post, but if you know about the tires, the ? would be we have the original 19 " rims on the car and it needs new tires, it may be cheaper for me to pick up larger rims from a newer mercedes with fresh tires. If so how large can I go without any mods? TY
Old Aug 12, 2024 | 03:08 AM
Carbonlord's Avatar
it is a 2009 ML350
