Starter and Horn don't work.
Old Aug 12, 2024 | 08:47 PM
user 26364748's Avatar
2008 ML550
I just had the starter replaced a few weeks ago and the wipers stopped working along with the 12v cigarette lighter socket. I searched the forum and found a fix, replaced several relays, and solved those problems but now have another one. When replacing a relay, I accidentally put it in the wrong spot in the fuse panel under the hood. I quickly took it out but it must have shorted something. I read a similar post, same symptoms, that said the fuse box itself was shorted.
Is there a way to open the fuse box to check? Does anyone know how to open the fuse box? Any other advice is appreciated. Thanks
Old Jan 31, 2025 | 03:14 PM
anavabi's Avatar
2006 ML500, 2008 ML350
Just came across this post. Did you resolve it in the end. Did you get to check the front prefuse?
