Parasitic drain - fuse 14 & 41?
Old Sep 6, 2024 | 12:57 AM
intel's Avatar
c300
Hi all,
I am trying to locate a parasitic drain in a 2011 ML350, utilizing an Amp Hound 2 device I found the following fuses to have current.
Instrument panel
Fuse 14 - EIS [EZS] control unit: 7.5 amp
Luggage compartment/trunk
Fuse 41 - Overhead control panel control unit: 25 amp
Fuse 14 is pulling 0.1 amps
Fuse 41 is pulling 0.06 amps
Any thoughts?
Thanks!
Old Sep 8, 2024 | 11:42 AM
vesiadog's Avatar
1998 SL500,2011 GL550,2009 ML350,past 1995 E320 Cabrio ,2005 ML500,2006 ML500,1996 SL500,1972 280SEL
draw
Here is a little quote i found “
Parasitic draw
This is when electrical devices continue to draw power from the battery after the engine is off. A normal parasitic draw is between 50 and 85 milliamps for newer cars, and less than 50 milliamps for older cars. A parasitic draw that's too high can shorten the battery's life”
I would put a good 24 hr charge on the battery and start from there. I found that not all batteries get a good 100% charge from the alternator. When my GL or Ml start to sound a little weak on turning over .. I put them on a good charger .
So your .1 or 100 milliamp draw imo should not be causing any issues.
Old Sep 12, 2024 | 07:01 PM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Here is an excellent video that might assist.
