Remote unlock works badly
My 2010 ML350 W164 doesn't open or close easily using (both) the remote keys. Sometimes I need to press the open or close button for 10-20 times walking around the car and it unlocks or locks after a while. But after riding the car for some time it is ok again and the carlock reacts like it should be...
The car always does crank normally so main battery isn't dead. The battery in the keyfob is new.
So what could be the issue? 🤔
Auxiliary battery?
Antenna problem?
Fuse or SAM?
Any insights?
Auxiliary battery?
Antenna problem?
Fuse or SAM?
Any insights?
Joshinator99 (09-14-2024)
One of my keys has just came back from a "refurbish job" and was tested 100% ok. The other key always worked fine, now bot have the same problem so logic dictates that the problem is probably on the car side.
Originally Posted by Vmaxxer;[url=tel:9032564
9032564[/url]]One of my keys has just came back from a "refurbish job" and was tested 100% ok. The other key always worked fine, now bot have the same problem so logic dictates that the problem is probably on the car side.
Joshinator99 (09-15-2024)
2010 ML550 VIN WDC1641722A564750, 2010 B180
Mine does that in certain locations where there is a heap of radio interference. Is yours location specific when acting up or does it do it everywhere?
Update:
Replaced the Auxiliary battery and the remote key works perfect again. So that small aux battery was bad... but I didn't get any warning on the dashboard and not in the diagnostic device.
The process to get to that battery (under the passenger seat behind the main battery) was a pain in the ***. To remove the main was heavy! literally.. 24kg to lift out of the car in an impossible position. But I managed.
job done.
job done.
The following 3 users liked this post by Vmaxxer:
Update:
job done.
job done.
after working for an hour or two I'm back at square one.
The search continues.
I found out that:
A) my recently refurbished Fob completely stopped working, again.
B) my spare fob had a flat battery although I recently replaced it
All at the same time. What are the odds?
At least all is working again with one key.
BlackML550 (10-11-2024)
