Right Side Headlight Low Beam Not Working
Old Oct 3, 2024 | 12:50 PM
rted's Avatar
RX 350
Hello,
My Right side low beam headlight stopped working. After inspection the H7 bulb is ok but I noted the insulation on the wires disintegrated. So the wires must have created a short.
The main headlight plug has 4 wires. I confirmed the Yellow/Blk(4) wire has power (13.7VD ), however no power is getting to the H7 Bulb. So can I assume it is a failure in the HEADLIGHT?
Can it be repaired? or must it be replaced. They are asking between $300 and $450.
Your help in this matter is much appreciated!!
Old Sep 16, 2025 | 01:40 PM
gbm's Avatar
gbm
2013 C350 AMG Sport+, 2006 ML320
Did you end up fixing it? My right side high beam is not working, all other lights work.
I think replacing it will fix it? with this: https://www.ebay.com/itm/353257064118
