Wire routing from rear SAM to driver side dash for trailer
Hi. I'm adding an OEM trailer hitch, probably would have been better to sell the vehicle and buy one with it, but it's a little late for that. Anywho, I've added the trailer hitch and ran the wire harness up to the rear SAM. Next is getting the 4 wire green plug from the wire harness up under the drivers side dash for the electric brake control. I'm seeing two ways to do it.
1). Either run up the center of the vehicle under the center console
2). Run it across under the rear seat and then up along the left side of the car
I've had the center console out and removed the front and rear floor trim plates from the passenger and drivers side. I'm not seeing a good path through using either method. I'll probably end up removing the connector so I can run the bare wires and don't have to push the housing with them.
I'm curious if anyone has given this wire routing a try and have a recommendation/suggestions on how to do either one. This is the last thing I need to do before have the dealer replace the rear SAM and reprogram the new one I bought that supports the trailer option.
Thank you!
I've retrofitted two early 2007 GL that did not have the wiring, The part number for the factory wiring harness for trailer controller is 164 540 69 13
Mercedes expectation is that you run the wiring through the rear SAM so it can be included with the original equipment 7-pin connector. The part number above plugs into the rear SAM.
I'd highly recommend the original equipment 7-pin wiring that connects to the rear SAM, as as this gives you dashboard messages as regards trailer bulbs. Also, if yours has Airmatic it will not permit the usual highway speed vehicle lowering when a trailer is detected. This is a CANbus electrical and you DO NOT want to "tap into" wiring to get trailer lights.
On 2007 GL if car wasn't factory equipped with hitch, a new SAM was required. I think by 2010 not. I'd search this forum for previous threads on this. Pretty sure the GL forum has the official Mercedes instructions attached to a post and they could very likely be here too.
Any thoughts on what happens if you just disconnect the rear SAM for a short trip to the dealer to reprogram the new SAM. I'm guessing lot of errors, but I don't see why the engine wouldn't run. You can swap the two in a couple of minutes, but the dealer will probably charge 1 hr labor for this simple task.
2. Do you know the fuse location for the brake control circuit?
I have watched three YouTube videos on the Curt, and have decided that it looks like a better choice. The only potential problem is, because of the awkward positioning of the 7 pin outlet up under the bumper on my car, if the Curt will hang down too far as it will be pointing toward the ground when plugged in.
thanks also for tip on the circuit tester.
As you probably know, the newer cars with all the collision and blind spot sensors disable the associated systems when a trailer is connected by sensing the trailer's light circuits. This prevents the trailer from false triggering the sensors. The 7-way connector circuits are disabled until an adequate load is sensed (about 20 mA, I think). In the absence of an adequate load being sensed, the 12 volt circuit to the 7-way connector is disconnected. I assume your Tekonsha controller was getting 12 volt power from the 7-way, so its Bluetooth was powered?
The power/pairing light on the Curt does not light when plugged in and the Tekonsha gives a “no connection “ error code after trying to pair.
Both units do pass the lighting signals through to the trailer, though.
its a CAN bus electrical system and apparently it doesn’t send power to the plug until it detects there is a trailer connected. Apparently a tester isn’t the same thing
