2011 ML550 diag code 9068 RR window hall sensor does not supply a signal
Old Dec 14, 2024 | 07:04 PM
markloch's Avatar
2011 ML550 2013 GLK350
Symptom is the window will go up (or down) only a couple inches at a time. This is NOT a window reset issue - done that a bezillion times with the almost dozen MBs we've owned.
Scanner throws 9068 - M1 0/6 (Right rear power window motor) The right rear Hall sensor does not supply a signal.
So where's this sensor? Or could this be a problem not with the sensor but something else?
