W164 NO CRANK NO START??
Got a 2009 ML320 CDI, I’ve just rebuilt the conductor plate on it and it’s been sitting for around a year.
I’ve connected a new battery and the car has power the ignition works as it should but will not turn over when key is turned, I have jumped the starter motor and it turns fine any advice is greatly appreciated.
I’ve checked basic stuff like fuses etc I can hear the fuel pump prime when ignition is in position 2
thanks all as am scratching my head
I would check if starter gets voltage or not, is not go to relay and see whats happens there both signal and power terminals
Any thoughts?
