Motorcycle Hitch carrier on W164
"A Mercedes W164 typically has a trailer hitch tongue weight capacity of around 350 lbs. when equipped with a Class 3 hitch, which is the standard for this vehicle;meaning it can handle a tongue weight of up to 350 pounds while towing a trailer with a maximum weight carrying capacity of 3,500 pounds."
Is the above information correct?
The weight of the bike is 251 pounds, add a full tank of fuel (approx. 25 lbs.) and the carrier weight (51 lbs.) for a total of 327 pounds. Therefore, this should be ok with no issues?
Has anyone done this before and all works out ok, maybe anyone have a picture with the carrier and bike installed?
Many thanks in advance.
I hope the group helps you out.
