Check Engine Light After MAF Replacement
Old Mar 22, 2025 | 02:24 AM
patriotaki's Avatar
c250
Hi everyone,
A mechanic replaced my Mass Air Flow (MAF) unit because the old one was damaged. However, the check engine light is still on, and a diagnostic scan shows "Mass Air Flow too large."
I took it to a trusted mechanic, who found that the previous one didn’t transfer the original MAF sensors to the new unit. He suspects the replacement was a cheap aftermarket part, and the sensors aren’t functioning correctly.
How can I find a reliable replacement (part number) that won’t cause issues? Any recommendations?
ML 320 (W164, 2009 Facelift)
Thanks!
Old Mar 22, 2025 | 04:36 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
When you replace these you have to disconnect the battery (both negative and positive terminals- not just one). A friend replaced this 3 times until he read the instructions. On the 3rd replacement part he finally disconnected the battery, left it alone for 30 minutes, and problem was gone - just as the instructions that no one bothered to read, said.
Old Mar 23, 2025 | 12:41 AM
alive19's Avatar
GL320 2007
You need to reset the MAF sensor in adaptations.
Basically your sensor is fine, but because it has the old sensor trim in memory, the difference is too great and it gets an error. 30min with no battery may reset this, otherwise you'll need a scan tool that can access the adaptations (noting you are supposed to reset air filter adaptations each time they are replaced as well).
Old Mar 31, 2025 | 06:42 AM
BlackML550's Avatar
Did you sort this? What was the fix?
Old Mar 31, 2025 | 01:43 PM
jimyj's Avatar
E320
You're spot on about the possibility of a cheap aftermarket MAF sensor causing issues. These sensors need to be calibrated correctly, and if the replacement part doesn’t match the original specs, it can lead to problems like the "Mass Air Flow too large" code you're seeing. I’d recommend checking if you can find an OEM part number for the MAF sensor, as using a genuine part often helps avoid these types of issues.
If you haven't already, it might also be worth double-checking all the connections and ensuring there are no air leaks in the intake system that could affect the readings. Sometimes, a simple vacuum leak can throw off the MAF sensor readings and trigger the check engine light.
