Aircon issue linked to overhead control unit fault?
Old Apr 8, 2025 | 06:24 PM
andytrueman's Avatar
2006 ML320cdi Sport
My ML164 has an intermittent fault with the aircon. It has gas and makes cold air, but after about 5 minutes of driving it stops making cold air and the windows fog up. The wipers also work constantly when in auto mode. I finally found an article that linked these exact symptoms to a faulty overhead control unit which apparently is near the rear view mirror. Has anyone here had a similar issue and was it solved by replacing the control unit?
Thanks.
Old Apr 10, 2025 | 06:16 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
If you scan for codes you'll see there is an overhead control unit module. Scan it first and see what of any codes you get.
