AirMatic Random dropping
Their leaks can be maddeningly intermittent because the leaks usually are at the fold, which will change position based on the ride height when stopped, whether the vehicle is on an incline, and so forth.
It is easy to check the air springs. Raise the ride height and spray soapy water on the bags. Look for foam.
As with the electrical problems, people insist on diagnosing from the outside in: "This symptom, that symptom, the other symptom." They want to sit in the driveway and stare, trying to make the vehicle reveal its secrets. I know because I've been there myself.
You have a problem that might be electrical? Check the battery and alternator. A problem with the air suspension? Check the air springs for leaks. Always do these things first. Don't delay, because a failing alternator will ruin the battery, and leaking springs will bring down the compressor and, depending on climate, the valve block.
