Reverse Camera
Old Sep 9, 2025 | 09:55 AM
imtheking's Avatar
Former R230, W220 and W221 owner
Reverse Camera
2010 ML350- OEM Reverse Camera
Anyone replace the camera on their ML? Mine looks fuzzy. Tried cleaning the lens and it still looks horrible.
I see you can get the part from Ebay for $100 or so and it looks like it's plug and play.
Help?
Old Sep 9, 2025 | 06:08 PM
AL5461's Avatar
W221 S500
If it's a factory fit camera it will be plug and play.
You need to remove the tailgate handle trim, 2 T27 torx screws externally and 2 10mm nuts inside once the interior trim panel is removed... Early cars this is only clipped in place, later cars should be similar but watch for hidden screws and any lights on the trim panel.
The camera is then accessible and should simply unclip from the tail gate and the harness connection will be obvious.
Old Sep 10, 2025 | 09:42 AM
imtheking's Avatar
Wonderful! Thank you!
I found this video to:
Old Sep 11, 2025 | 07:02 PM
AL5461's Avatar
W221 S500
In the process of retrofitting the factory set up to my recently purchased '07 ML, so it's a familiar process.👍
Old Sep 12, 2025 | 08:59 AM
imtheking's Avatar
Wondering why you went with a 2007 with all the balance shaft issues.....
Old Sep 12, 2025 | 09:07 AM
AL5461's Avatar
W221 S500
It's the OM642 and it cost £600.😂
Old Sep 12, 2025 | 01:42 PM
imtheking's Avatar
ah ok.......
