W164 Parking Sensors Retrofit?
Front and rear sensor to body harness.
Body harness Bumpers to ECU/CANBUS/fuse box.
Parktronic ECU.
Rear dome light with display.
Front dash top display.
Possibly harness from ECU to front and rear display. (Might be part of body harness or taped back within roof and dash harness.
Centre console switch panel.
Access to WIS and Xentry.
With all the parts to hand allow a weekend to fit it.
Watch out for corroded bumper fixings.
It's a question of identifying, obtaining and fitting the parts. Hardest thing will be getting hold of a serviceable wiring harness because most breakers cut the plugs off and older harnesses are not so readily available from MB.
Get hold of a decent copy of WIS and EPC and spend a couple of weekends researching the parts numbers and availability. If you can't or won't do that you have 3 choices...
1. Pay someone else to do it.
2. Buy a car already equipped.
3. Live without.
3. Live without.
Will research and also have a look around for parts here, many MLs here for parts available. Fortunately, they don't strip the parts off here beforehand, they only remove a part when someone needs it.
Let's see if I can scrape it together. And how much they ask for it.
Adding third party sensors would be cheaper and easier, but I don't know how good those would be.
And most come with 4, while ML has 6 in the front. And there's often no display, or it looks bad.
Was also thinking about installing 360 parking cameras, I've seen sone headunits that come with cameras for a 360 view.
I'm not sure if parking sensors would be necessary if you go for cameras.
Aftermarket less certain and you don't know how it integrated to the car, or not, until it's too late.
