Spec'd out my truck
Also, it provides both a visual (red triangle) and audible (beep) warning. The audible warning only triggers if you hit the turn signal stalk.
Anyway, no more sales pitch from me, I promise
Once in the correct position, your side mirrors will be very strange in your peripheral vision. However, stick with it and you can completely trust that a glance in your mirror that doesn't display a giant car is a clear lane. I've been "reformed" for at least a couple of years and still cannot believe how well this works. Many people I've shared this with revert back to their old and blind position just because they didn't give themselves time to adjust. For me, it was truely a revelation
Edited to add: To make a quick setting, for the driver-side mirror move you head towards the driver window so that your cheek is touching the glass then adjust your mirror to just see the side of your car (a "normal" position for the mirror). For the passenger-side, lean towards the center of the car such that your eyes are "down the center" of the car and adjust that mirror to just see the side of your car. That works every time for me.
One more edit: Pull up to a stoplight such that the car next to you is in your blindspot. Then adjust your mirror until that car you couldn't see becomes a big, mirror-filling image and you are set.
Thanks. My plan is to order in May 2012 the 2013 ML-550 Model with all available options (including Designo) for August/September 2012 delivery. By that time I expect all new equipment (V8, HID Lights, Leather, OFFROAD, Night-Vision etc...) will be fine tuned for production.
- Diesel here is more expensive than premium, sometimes 10% or more.
- Diesel fuel is not available at all stations, probably about 1/3 in urban areas
- Diesel fuel quality seems real iffy sometimes (water, etc.)
- Diesel maintenance is higher with DEF, fuel filters, etc.
- BlueTEC weighs weighs 287 lbs. more than the gas model; not good for handling
- Early models have had initial rough running when cold
- Environmental advantages seem pretty minimal from the data I've seen
- I'm used to a higher revving vehicle
- I have no real need for the higher torque
- $1,500 added cost
- Do probably 80/20 urban/highway driving
Balanced against that are the better resale and the fact that the puddle lights work!
I have to admit, the new 3.5L DI engine is really great!
This rollout has been a fiasco from my point of view, and if there was an alternative I was interested in, I'd be on it. I had the very first deliveries in my state of the W163 & 164 and all promised options were available from the start. Now we've seen delays in several options and even floor mats and roof racks are on backorder. Something in MB's planning is seriously awry. When you **** off your enthusiasts and don't care that's a problem coming.
