Anyone find a solution to the headlight halogen problem?
Has anyone found a solution to this? (Not ebay hid kits)
I did finally find the oem color bulb this week. So I am finally somewhat satisfied.
It is definitely no match for the all led headlights of my 2012 a6 but there is no other option.
Retrofit of factory parts when theyr'e available won't work either due the complexity of the auto high beam and turning (I believe?) Even if it's just the auto leveling, that requires sensors on the suspension, so if possible would be a minimum $2000 upgrade just for parts alone.
First: how do you take the door off from the wheel well? Do you have to pull out the plastic rivet first then push the door up?
Second: where did you mount the ballast?
Ballast,I put tied up with some zip ties behind the lighting housing
Update,
I found a good oem 4300k bulb finally!!!
http://www.ebay.com/itm/2-HID-Bulbs-...-/260735114683
Update,
How do you remove the bulb from the clip?
Also, where did you route the wires (did you cut a hole in the round cover or some other way)?
I went with the 6000k bulbs.
Thanks!
I cut a slit in the round plastic cover and then sealed it with silicone.
Plus, why you looking at Nissans anyway - They make the Nissan Juke you know?
caps, relays, 4 different kits, 4 styles, doesn't work all the time.
Just a 411, so if someone has a kit that works 24/7 let me know... please provide video proof though... because at this moment in time, I am calling the BS flag.
same here with the flicker, but it is unacceptable. i threw it on a meter and seen that it steps down the voltage when it is light outside causing the issue. I am going to make a regulator today and see how well it works. definitely going to have the HIDs come on with relays at the front relay and fuse box.
I even tried hooking up the relay kit directly to the fuse box(under hood, main red power wire with thickest gauge) as well and had one of the OEM headlamp plugs trigger the relay when the lights are turned on. This did not work for me since I couldn't fool the other headlamp plug since the resistance/amperage/voltage(sorry about my lack of expertise in this area) must be different from the other plug when triggering the relay. As a result, the OBC would SHUT OFF all power(after blinking the hid bulbs 2-5x) to the headlamps; so my ML wouldn't have any headlights! Very dangerous and I don't want to chance that at all when my self or wife is driving the vehicle at night.
So, the kit I described in my earlier reply only blinks the passenger side 1 out of 10 times or so when i pull into the garage with Auto On. It never blinks when I start the car either in the garage. I even drove the car for a 1 hr trip each weekend during the night and the remain lit, nice and bright, without much scattered light at all. I also do not have any melting issues due to the higher wattage.
My other kits would flicker/strobe, blink 2-5x then remain lit 50% of the time, blink 2-5x then SHUT OFF the headlamps altogether(Yikes!), and the darn relay kit was a failure for me as mentioned above.
Yes, you have to slide the inner wheel-well up from front tire side, after you pull out the stubborn plastic rivet that I broke, then twist the bulb 1/8 to the left and pull out. The OEM metal clip is what holds the bulbs in so you have to reuse this metal clips with the hid bulbs.
I hope this helps and go ahead and PM or email me if you want info on the $150 kit that I purchased from ebay. the seller agreed to allow me to release to individual buyers outside of Ebay to help save you and him some $.
believe me.
