Fuel tank capacity
Then I ran across this on the Daimler website, which shows an 20.6 gallon "standard" tank and 24.6 gallon "optional":
"The range calculated for a full tank of fuel is particularly impressive. With an NEDC consumption of 6.0 l/100 km, the ML 250 BlueTEC 4MATIC with standard 70-litre tank can cover around 1170 kilometres before needing to stop for fuel. If the vehicle is fitted with the optional 93-litre tank, a distance of up to 1500 kilometres is possible between refuelling stops.
Vehicle range at a glance:
------------------------ML 350 BlueTEC 4MATIC - ML 350 4MATIC BlueEFFICIENCY
NEDC combined l/100 km -------6.8 ----------------------------8.5
Fuel tank capacity in l ---------70 -------93 ---------------78-------93
Range per full tank of fuel km--1030-----1370-------------920------1090"
I'm guessing the 27.7 is an error, unless anyone has been able to refuel with more than 25 gallons?
Come to find out I still had 1.5 gallons left. Because I was still able to put in 23.x gallons in.
]....then pumped in 23.4g @ 68deg F.There is no way there were 4.3g left in that tank. I'll go with 24.6g...too bad they don't show how many gallons left instead of expected remaining miles to go [which switches to a gas pump icon when running low...not very useful].
Sept2, 2013 / 2012 ML350
