AMG Door Pins. They are almost worth the price.
Old Sep 27, 2012 | 08:34 PM
GTscrub's Avatar
2013 ML550
I just saw these on eBay.. I like the chrome much better.
Old Sep 28, 2012 | 02:50 PM
twodivers's Avatar
'15 GL350 Bluetec
Originally Posted by GTscrub
I added the AMG door pins last minutes for $140. I hope that includes all four doors.
You might want to check on that - they retail for $70 EACH.
My dealer gave me the short pins (part # 123 766 00 22 9051) for free and I put them on. More comfortable, for sure. Best of all, no cost!
Old Sep 28, 2012 | 08:22 PM
GTscrub's Avatar
2013 ML550
http://www.mbusa.com/mercedes/access...%3AA0007660228
It doesn't say on the site. So just front two doors?
Old Sep 29, 2012 | 09:56 AM
GTscrub's Avatar
2013 ML550
You are right. It's just for two door pins.
Old Feb 25, 2013 | 06:23 PM
Masterbuyer's Avatar
2013 ML550 Paladium Silver/Brown Satin Ash
I just bought these lock pins off of ebay for about $53, shipped from California.
http://www.ebay.com/itm/Mercedes-Ben...e90fd1&vxp=mtr
But if you search with the string...
"Mercedes Benz MB AMG Emblem METAL Door Lock Pin Pins 4pcs W203 W210 W211 W220"
..you might find the same one's a few bucks cheaper from another seller. Even though they say AMG on the ends, they are knock-offs, for sure. But that price is a lot better than paying for the OEM versions. Quality was perfect.
They didn't fit flush to the top of the door on my 2013 ML550 like how I've seen pictures of how the OEM do, b
ut extend up just a about a quarter inch...enough to grab with my finger tips and open the lock. I prefer them protruding a little like this, rather than be worried I couldn't open the door in an accident if for some reason the other two methods didn't work.
Attached are some before-and-after shots. I removed the those black ugly-shaped things with a set of piers. They were pretty tight at first, but eventually unscrewed. I used my hands to screw on the new metal pins until I couldn't turn them any further.
Very happy with how they look and for what little I paid (relative the the OEM's).
Attached Thumbnails AMG Door Pins.  They are almost worth the price.-capture.jpg   AMG Door Pins.  They are almost worth the price.-2013-02-25-12.59.18.jpg   AMG Door Pins.  They are almost worth the price.-snipimage.jpg
Old Feb 25, 2013 | 09:21 PM
300DTurbo's Avatar
300D Turbo 1984
Liking the open grain... please post a pic of them in the locked position
Old Feb 25, 2013 | 11:50 PM
  #32
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
AMG door pins
OEM ones are $40 each list ($160/set of 4). The amount protruding can be adjusted by how far you screw them on - use a little blue Loctite.
Old Feb 26, 2013 | 04:00 PM
  #33
Yep, that price it crazy....how do they possibly justify$160 for a set? It is just simple machined metal.
Here's other type that also looks pretty good, and ever cheaper at $35 for the whole set, plus $10 shipping:
Mercedes Benz Carbon Door Lock Pin Pins W203 W210 W211 W220 C E S CLASS 4PCS r6
http://www.ebay.com/itm/Mercedes-Ben...387f0d&vxp=mtr
Old Feb 26, 2013 | 05:02 PM
  #34
petermk's Avatar
2013 ML350 BTC
I got the OEM ones for $30 apiece online.
Attached Thumbnails AMG Door Pins.  They are almost worth the price.-20130131_212738.jpg
Old Feb 26, 2013 | 10:19 PM
  #35
They are really finely finished, almost like jewelry, with brushed sides and polished laser-engraved tops. The eBay ones poseted here look cheap by comparison. Truth is, though, noone but us on this forum would ever notice the difference.
Old Feb 27, 2013 | 08:41 AM
  #36
challer's Avatar
2013 ML 350 BlueTEC
Few would notice, and they should be standard on the ML as the plastic pins are inconsistent with the rest of the vehicle. But I put them in simply because of the poke in the arm I got every day at work scanning the security card. Truth is you only need them up front, at the end of the day.
Old Feb 27, 2013 | 11:02 AM
  #37
Here's some photos with the door closed...not the best quality shots, but they at least show how much they protrude when closed. I tightened them on as hard as I could with my fingertips. I suppose I could try screwing them in more using some form of a cushioned pliers, but not sure I can or if it would be wise...wouldn't want to twist off the shaft they screw onto. But, like I said, I like them a bit up so I can still grab the top and unlock the door that way.
The quality seems perfect. I couldn't imagine them looking better or paying anything more, especially three more for the OEMs....unless I had money to blow.
Attached Thumbnails AMG Door Pins.  They are almost worth the price.-back.jpg   AMG Door Pins.  They are almost worth the price.-img_0897.jpg   AMG Door Pins.  They are almost worth the price.-img_0888.jpg
Old Feb 27, 2013 | 07:05 PM
  #38
27T's Avatar
27T
13ML BT
The OEM AMG pins allow you to install flush. Matter of preference plus cost. I prefer the flush look.
Old Feb 28, 2013 | 01:33 PM
  #39
I just tested them out to see if they could be tighten down further and I think they can with some effort. I, too, prefer the look I've seen of them being flush when locked....but maybe I'm just claustrophobic, but I feel better having a little bit showing to grab if need be. I keep imagining myself in an accident, like having run off the road and submerged in a pond of water somewhere, and I can't get the door unlocked and reaching for the pin but since it's flush, can't grab it and realized I'm trapped. Okay, I admit, I I've probably watched too many horror movies.
I know pulling the door lever also unlocks the door....but is that a mechanical or electronic action? If it's mechanical, it's probably then no different than lifting the pin. But if electronic, and it is all shorted out due to water, then that lock pin may be the only way to unlock the door.
Old Feb 28, 2013 | 01:34 PM
  #40
I just tested them out to see if they could be tighten down further and I think they can with some effort. I, too, prefer the look I've seen of them being flush when locked....but maybe I'm just claustrophobic, but I feel better having a little bit showing to grab if need be. I keep imagining myself in an accident, like having run off the road and submerged in a pond of water somewhere, and I can't get the door unlocked and reaching for the pin but since it's flush, can't grab it and realized I'm trapped. Okay, I admit, I've probably watched too many horror movies.
Old Mar 2, 2013 | 02:07 PM
  #41
kcl489's Avatar
Mercedes Benz ML550 2013
Hello everyone, Can anyone explain me how to change my door pins? i have to pull the original pin or just twist? its for a ml550 2013
Old Mar 2, 2013 | 02:18 PM
  #42
another_geek's Avatar
'16 Jaguar F-Type R, '21 GLE63s
They twist off/on
Old Mar 2, 2013 | 02:21 PM
  #43
kcl489's Avatar
Thank you!!
Old Mar 2, 2013 | 07:24 PM
  #44
Originally Posted by another_geek
They twist off/on
Mine were very tight at first when removing them. Needed a pair of pliers to grip them and slowly twist them off. For the front, lowering the window helped provide better access to them.
Old Mar 18, 2013 | 11:15 PM
  #45
TOLeafs's Avatar
Bmw
Just got two pairs from my local mb dealer. They charged me $40 per pair
Old May 23, 2022 | 07:47 PM
  #46
hutch300's Avatar
2022 GLE450
Old thread revival! I have a set of 4 of these if anyone is interested. I for some reason only have the boxes for 3 of the 4. Send me a PM if interested. They are the real MB "AMG" ones - not the ebay cheapies. I just traded in a 2014 Blutec on a GLE450
Old Jul 28, 2022 | 05:52 PM
  #47
hutch300's Avatar
2022 GLE450
Last call on PMing me for the pins before I toss them. Just want shipping - flat rate small box. They were not cheap but I want them to have a good home in an ML! USA only folks.
