Weather Tech MacNeil Automotive Custom Fit Mat Analysis with pictures of all 4 mats.
Passenger side (C) there is almost 4-6" of less coverage than the factory mats at the front most portion of the foot-well. I left the factory mats on underneath for added protection and "soft/padded" feel under the WT. (no accelerator to worry about on this side)
Rear analysis: (A+) Fantastic and precise fitting. No snaps, but the fit is so excellent no problem here with mvmt. Even when I drop a cup of coffee or spill anything. Perfect coverage of the center segment that is left completely exposed by factory set. (This is a MUST BUY)
.Cargo Area: (B-) Shifts around and the fitting is B-grade at best. It will be useful for groceries and such that may leak? Dirt from shoes and boots washes off easily. Dogs slide around, but easy to clean. (Not necessary if you don't actively use the trunk). May become trapped in the auto trunk if it slides outward when removing cargo. Not a good design.
