Removing visor warning stickers
Old Jul 29, 2012 | 06:44 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Any tips on doing this - Heat gun? Goof Off?
Old Jul 29, 2012 | 07:10 PM
LazKat's Avatar
2013 ML350
Either way it's probably going to make a mess. What is the end result you're looking for? Just a clean surface?
On my GM SUV, another online forum had someone who was offering vinyl overlays with the vehicle logo to cover the seatbelt warnings on the visors. It vastly improved the look. There are vendors on eBay who will make custom stickers with whatever you desire. Maybe we could find someone who will make them and provide contact info here. It's a cleaner solution.
I don't have my vehicle yet and so can't determine the exact size needed.
Old Jul 29, 2012 | 11:00 PM
Keyser Soze's Avatar
2010 GL450 and 2016 GLE350
A hairdryer works well...............Don't get carried away, just use enough warmth to enable the label to be pulled away without tearing.....
Old Jul 30, 2012 | 01:43 AM
iankayem's Avatar
X350d GLE500e 2017, ML350 BlueTec 2012(sold), A200 2013, ML350CDI 2009(sold), Aston Martin DB7 2003
I know this sounds crazy but CRC Clean-A-Carb (toluene) works well. Does not harm velour, so I believe it will be safe on the visor.
Old Jul 30, 2012 | 04:07 PM
YYZ-E55's Avatar
MY17 E43 Matte Selenite/Macchiato Beige, MY16 GLE350d Tenorite/Crystal Grey, MY17 B250
Probably safer to order the euro sunvisors.
Old Jul 30, 2012 | 11:42 PM
The ML visors are vinyl. I've done it on fabric before.
Old Jul 31, 2012 | 11:10 AM
hutch300's Avatar
2022 GLE450
Have you attempted this yet Greg?
Old Jul 31, 2012 | 06:57 PM
Warning sticker removal
Are you saying you've done this specifically on this vehicle or one with vinyl visors?
Old Aug 1, 2012 | 07:59 AM
Cyber GS's Avatar
2013 CTS-V, 2017 Audi Q7 / Past MB's: 2011 ML350 & 2012 ML350
When I have removed labels in the past on vinyl, glass or even painted surfaces (not on visors) I used the hairdryer method first and then removed the remaining adhesive that gets left behind with WD-40.
I just spray a little onto a cloth and work it in, I have never had a problem with it damaging the surface or removing the color.
Obviously try it on an inconspicuous spot first to make sure it doesn’t damage anything. I would be shocked if it did.
Old Aug 1, 2012 | 08:47 AM
YYZ-E55's Avatar
The visors in the W166 are plastic and the labels are actually pressed into the plastic.
Old Aug 1, 2012 | 06:47 PM
2006 ML, 2010 GL.........Wife likes them on her 2007 ML.
Old Aug 1, 2012 | 11:36 PM
Likes them?? hmmm...
Old Aug 6, 2012 | 07:52 PM
listerone's Avatar
2018 BMW 540d
I had good results with Goof Off.If you look closely you can see evidence of the stickers but,at a quick glance it looks good.
Old Aug 6, 2012 | 08:44 PM
iankayem's Avatar
Decided to remove mine on the W164.
Drivers side on the mirror cover - clear label came of with slight sticky feel that cleaned up with metho.
Passenger side - coloured label cover came off leaving all scipt and white back ground and yellow highlights clearly legible. I rubbed this with my thumb and the gum balled up leaving a perfectly clean surface. I did rub with metho, mainly for the smell and perhaps a sip.
Old Aug 7, 2012 | 10:19 AM
listerone's Avatar
2018 BMW 540d
I worked for years in a large hospital's ER (I think you Aussies call the "A&E" Departments) and we'd see chronic alcoholics from time to time who had downed methanol in desperation.It's absolutely lethal in surprisingly small amounts.I know you're kidding but it's wise to be careful with that stuff.
Old Aug 7, 2012 | 08:44 PM
iankayem's Avatar
On a more serious note, we actually abbreviate the A&E to "Emergency Ward".
And one reason for our preference for diesel, is the difficulty getting PULP in outback regions. The only petrol available is OPAL, which is 91 octane low aromatic fuel promoted for the anti sniffing program.
