So many problems with my 2012 ML350 Bluetec
My first request was in Nov 2012, my second was two weeks later on a Wed when MB refused my first request.
Less than 24 hours later my GM called to tell me that MB was working out the numbers to buy the ML back. I had the new ML on the following Monday.
This was after two years of problems but the first time I demanded a buyback was Nov 2012. In retrospect I should have went harder on MBUSA a lot sooner, you live and you learn.
One example. The shop foreman road tested my previous 2011 ML and duplicated the trans hesitation several times with me and my wife present. He told us that he will need to adjust the shift adaptions.
The problem was since there were no fault codes MBUSA wouldn’t approve any work the dealer wanted to perform on the ML. Since I got to know the dealer very well he did it anyway and it corrected the problem for the time being.
I know there are some good and some bad dealers, but keep in mind that although it may seem like the dealer is not being helpful, it could very well be that MBUSA is giving them a hard time and tying their hands.
Since you were sad to find this thread, here is another thread with some more “feel good” reading for you. LOL
https://mbworld.org/forums/m-class-w...ml#post5485534
If the shop manager told me MB said they would not pay for the repair I would tell them that is not my problem and if the repair is not made under warranty I will see them in court. I think too many of us play footsie with these dealers and we need to take a tough position right away or they will walk all over us.
On the other hand, in my case anyway, it worked out better that I kept my cool and got the GM on my side. I honestly feel that if I didn’t I would still be fighting and going the legal route
I agree with everything you said especially with taking a harder position right away, that is the one area that if I had to do it all over again I would change. I initially contacted MBUSA when the ML was 3 months old, but I didn’t demand a buyback at that time. They got my GM involved and after the vehicle was repaired MBUSA did reimburse me 3 payments for down time but I never brought up a buyback.
A year or so later as the problems kept mounting I called my GM first and told him I was calling MBUSA and requesting a buyback. He told me he would back me up and do whatever he could to help me out.
My first request to MBUSA for a buyback was late Nov.2012. My second request (after they refused the first) was two weeks later on a Wed. The next day my GM called to tell me that MB was going to do a Substitution of Collateral and get me out of the 2011. I picked up the 2012 ML 4 days later.
So yes in retrospect I should have “put my foot down” a lot sooner.
But what is a warranty if not an assurance to the buyer that if anything goes wrong it will be corrected? If it is not that, then what is it? What court would see it otherwise? Does it mention that the problem has to be associated with codes? I don't think so. Here is what the warranty says:
"Our intention is to repair under warranty,
without charge to you, anything that goes
wrong with your vehicle during the warranty
period which is our fault. All we ask is
that you properly maintain and care for the
vehicle and that you have warranty repairs
performed by an authorized Mercedes-
Benz Center".
And: "You invested in Mercedes-Benz. Now Mercedes-Benz has your back.
All new Mercedes-Benz vehicles are protected by our New Vehicle Limited Warranty, covering defects in material or workmanship for 48-months or 50,000 miles, whichever comes first".
Now we all know it is easy to say something and difficult to put it in practice but where does it mention codes must be found before a repair can be made? As you said, I suppose one has to be faced with the situation to understand all this but it appears to be clear to me so I can't believe they even mention the necessity of codes when a problem surfaces - that is a non-factor for the owner in terms of the warranty agreement. The presence of codes and read outs are not (as far as I know because the warranty is 63 pages long and I have not read every word) even mentioned in the warranty as a prerequisite for repair. I just don't think it is right for MB to use this "code" thing as a cop out to fix warranty items and I would surely challenge them the instant they mentioned it.
One would think that if the shop manager, shop foreman and service director tell MBUSA that they all duplicated the problem, and in their professionally trained MB opinion they think “X” will correct the problem MB would give them the go ahead. Fault code or not.
But as you said and I agree, it is probably to curtail abuse. But if MBUSA suspects a dealer is abusing the system that is not the customer’s problem, that is for them to battle out with their dealer.
It should never come at the expense of the customer being taken care of.
The presence of a code can certainly point the service shop in the right direction and even pin point the problem and exact part at fault but that is all a code can do. The presence of this "code" can not fix the problem and that is what a warranty is for. A warranty is not there for identifying a problem or indicating where to look on the vehicle, which is the purpose of the "code". The warranty is for guaranteeing FIXING the problem. If the dealer replicates the problem, acknowledges it exists with or without the help of a code, determines it is not caused by owner abuse and has the remedy (all of which was the case with Cyber GS) they simply can not rely on an internal "code" presence to deny repair. If they say they can not find or replicate a problem and there is no code to help them then that is an entirely different matter. But that is not what they said to Cyber GS or to Katiesdad7.
If they told me no code equals no repair I would do what Katiesdad7 did. I don't think I would say more to the dealer other than see you in court, walk out and contact my attorney. I just would not spend any more time arguing with them.
Its probably cheaper for MB to loose a few cars to the lemon law than replace a lot of parts. I'm sure its all about the $$$$. Believe me, they wouldn't let the car be lemon lawed if it costs them a lot of $.
I'm sure they sold my car to someone else. Maybe they didn't make any $ on the deal but they didn't spend any tyring to fix it either.
Or some of it? It would be interesting to read what the court said.
Well said indeed
Labor cost to repair would have cost them more. When they sell these lemon cars, they don't offer extended factory warranty, and may be they even sell them without original warranty but with heavy discount which is my guess.
My dealer couldn’t have treated me any better and in my opinion was the game changer for me. I think that because they are a large, high volume dealer my GM had a lot of pull with MBUSA.
I know that my previous ML was sold, and since they bought it back before I took them to court it didn’t have a “lemon” title. So I am sure they got full market value because aside from the many mechanical issues, cosmetically it was immaculate inside and out.
I really hope the person who bought it got an extended warranty, I really do.
"Hi JFONTS
If that is the case then I recommend getting yourself a GOPRO or Sony Action Camera and film every time you drive. It sounds ridiculous but necessary from my perspective. Unless you have proof, I doubt that it would be in your favor at court. Lawyers are just representing you, and they just want your money regardless of winning or losing. Well, I could be wrong about hiring lawyer. A very good lemon law attorney with genuine intention of helping you might be worth while. However, my experiences with lawyers dealing with lemon laws were not great. They are just a bunch of used car salesman with law degree. Katiesdad7 who has problem with his ML too was able to replicate it to the service manager but he hired attorney anyway. Below is what he posted on the thread.
"Finally after being fed up with their BULL I put the service manager in the car and showed him. He then said they know about it be can't say anything because the update wasn't done. Lie #1. The same thing with the AdBlue light. They said that it was normal even though we all know it was not."
The first time I visited dealership for my problem was in Feb 2012, and they finally came to decision in Nov 2012. As you can see, it was a long battle with many visits, on monthly basis or even more frequent, to the dealer for the same issue with other new problems along the way with not a single error code registered on ECU.
Anyway, lawyers are just representing you, so that the other party cannot use your words against you if you say anything wrong. However, good lawyers can present cases with different angles that people never thought of, and I doubt that there are any good one as such dealing with lemon law.
I personally believe that MB makes and designs good cars. The problem is at their factory in Alabama. I think the quality control and craftsmanship aren't up to MB standard. My parents' E-class was purchased back in 1991 (I know I posted 1995 but my mom said it was late 1991 and I didn't care much about cars back then), and it runs without hiccup until now with everything working including power windows. I have a C-class back in 2008 which I sold to a close friend in 2010. It has been serving her with zero issue until today.
Good luck!"
I just read Katiesdad7's thread. He actually had to get his car inspected.
"At the hearing he INSISTED that the board inspect the vehicle. I really wanted them to inspect the vehicle because the problem was easily duplicated. Unfortunately for the MB attorney, who put all his faith in the dealer, he didn't know that. "
Therefore, problem that I had and yours which cannot be easily duplicated probably not going to have any chance at the court without strong supporting evidences.
As for video. I have a video of the problem. I will post it if I can figure put how. Its a real hoot. :-)
