cost estimate for adding Distronic after purchase? Also ambient lighting...
Old Jun 15, 2018 | 07:11 PM
  #76
guti's Avatar
Mercedes GL 350 Bluetec Diesel X166
test distronic GL dealer
Originally Posted by jrsmith_68
Interesting translation. All of the control units have to be coded once the SA codes are added. If the EIS ( electronic ignition switch) was not coded, that would be a major source for your issues. They should know immediately this is the issue when they review the screen I captured above.
Hello jrsmith_68, I have attached the details of the check that the dealer has made, to the Mercedes GL 350. I have taken the car this weekend, they have disconnected the radar video control unit, so I can ride with it. everything works less speed control and the right side of the parktronic. How strange, is not it? one side works and the other does not? just by disconnecting the control unit ?. do not all the sensors linked with the 4 radars of the corners go?
regards,
File Type: pdf
File Type: pdf
Old Jun 26, 2018 | 02:46 PM
  #77
guti's Avatar
Impossible. Today I took the car from the dealer. With all the installation of the Distronic but only with the functions that it had of factory. The car continues with the same faults. It is all installed. Only the video and radar control unit has been disconnected, and the software has been erased so that the car does not fail any more, and normal tempomat works.
Surely, Mercedes protects software downloads.
jrsmith_68, How did you download the 233 distronic plus software? At an official Mercedes dealer? or in another workshop?
Old Jun 26, 2018 | 11:48 PM
  #78
jrsmith_68's Avatar
Veteran: Army
2007 C350 2015 ML400 1968 Ford Mustang
Guti, after reading the error reports from the dealer, there are some issues that are concerning. A90, Collision Prevention Assist should not be showing up as an active module in your vehicle. It should have been removed, it will interfere with the radar control unit. Also your radar control unit (SGR) does not have the correct software, I thought you had the new one installed, the software should have been 0009025212. Was it flashed? Other error show that the radar control unit is not communicating with the other radar units.
As far as programming, I thought I had stated before that I did all programming myself. I had to use Vediamo since there is no official way I can SCN code my units without going to a dealer.
Old Jun 27, 2018 | 06:21 AM
  #79
guti's Avatar
I'm going to ask all this to the dealer. How are the control units flashed?
Old Jun 29, 2018 | 07:58 AM
  #80
jrsmith_68's Avatar
Veteran: Army
They are flashed by the dealer diagnostics system, Xentry.
Old Jun 29, 2018 | 11:27 AM
  #81
guti's Avatar
Thanks for your patience jrsmith_68.
Is it possible that the dealer's machine is blocked by the Mercedes Brand and does not allow these changes? The workshop manager yesterday showed me a demonstration and his machine is in direct contact with Mercedes. It does not allow some changes.
I'll have to find a workshop that has a pirate machine? with the Vediamo software ?. Apart from downloading software and changing codes, I would have to disconnect the cables from the Collision Prevention Assist module? regards
Old Aug 2, 2018 | 07:32 AM
  #82
guti's Avatar
Hello jrsmith, in my car the option "Collision Prevention Assist" had a sensor installed in the rear bumper. Did you remove it in your car? How many sensors did you buy for your car? 4 or 3? Did you do any additional installation for the front windshield camera, or did you just change it? I keep going around all this ... regards
Old Aug 2, 2018 | 11:15 PM
  #83
jrsmith_68's Avatar
Veteran: Army
Guti, remember my ML400 is a 2015 US model. I only had the CPA in the front. It had to be removed, as it is not compatible with Distronic Plus. Also, in post #20, I attached a document with all of the parts I used. Since I removed the CPA module, I had to add four MRR modules A0009055701. Being that your GL is a 2016 European model, it probably has new features, obviously rear Collision prevention. I am not sure how the architecture differs. From your pics I assume your model is still not considered the "facelifted" GL, correct?
Old Aug 3, 2018 | 04:05 AM
  #84
guti's Avatar
Sorry, the proximity sensor or CPA (ref A0009055103), is in the front bumper. The dealer left it, and added 3 more (A0009055701). The dealer did not eliminate it, because he thought it was the same as the new ones. I think that may be the problem of everything. My GL is a 2015 model.
Old Aug 4, 2018 | 12:42 PM
  #85
jrsmith_68's Avatar
Veteran: Army
Yes, if it is still in there it will cause conflicts with the Distronic. You will have two units essentially sending the same message and creating havoc.
Old Aug 4, 2018 | 05:58 PM
  #86
guti's Avatar
Hello jrsmith_68, I hope and I want the sensor to be the problem. the rest of the installation and the spare parts are correct. Now I have to convince the dealer to assume his installation error with the sensors, and that is difficult because they do not want to know anything about these changes, with the arrival of a new workshop manager. I will inform you of what happens. Thank you very much for your cooperation.
Old Jan 18, 2019 | 06:50 PM
  #87
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
What’s Distronic cost from the factory, just for reference?
Old Jan 18, 2019 | 07:06 PM
  #88
we47b1me's Avatar
'22 GLE 350 | '15 ML250 | '87 560SL | '19 GLC 300 | '12 C250 (sold) | '02 ML500 | '98 C230
Complicated question -- Distronic was included in package 997, the driver assistance package, and it was around $2800, or thereabouts.
Old Oct 29, 2019 | 05:52 PM
  #89
Sabath's Avatar
Touareg
Where is the end of story???
Old Oct 30, 2019 | 06:20 AM
  #90
guti's Avatar
The story has had a sad ending: I sold the Car. I think it was impossible to do it at an official dealership, or some of the installation was slipping away. In my case, I think that since I did not have a dead angle detector, it was impossible to activate distronic plus. My advice is that, if you do not have sufficient means and technical knowledge and a prepared mechanical workshop, do not try. You will spend a lot of time and money for nothing. But I have to thank everyone for your collaboration and especially jrsmith_68. Greetings to all, I wait for you in Spain
Old Oct 30, 2019 | 06:28 AM
  #91
Sabath's Avatar
Touareg
i have plans to try... if will buy ML W166 (day-to-day)
Old Oct 30, 2019 | 06:36 AM
  #92
guti's Avatar
And if anyone is interested in doing the installation, I have the 4 sensors, complete steering wheel switch, complete brake pump, camera, etc., everything except the electrical installation.
Old Oct 30, 2019 | 10:13 AM
  #93
diesel315's Avatar
E320 CDI, Jetta 06 TDI, GLS450 20, Boat:2 Volvo TAMD75+1 Kubota genset
Wow, Guti sorry to hear that was not possible.
Wish you the best on the replacement vehicle!
Maybe see you in Madrid or whereever one day!
Old Oct 30, 2019 | 10:46 AM
  #94
guti's Avatar
Ok, if you need accommodation in Madrid, I have tourist apartments:
https://www.booking.com/hotel/es/bausa-19.es-ar.html
and also on the beach of Benicassim (Castellon, Valencia)
https://www.booking.com/hotel/es/vil...sim.es-ar.html
Old Nov 30, 2019 | 04:20 PM
  #95
MB13GL350's Avatar
2013 Mercedes GL 350
Hello JrSmith and Guti,
I am considering doing this swap but I am slightly terrified as well. Jrsmith does this activate all safety features? We say distronic, so obviously it activates the cruise control that monitors distance. But does it now steer automatically for you and actively stop you from drifting lanes in a lane change with someone in blind spot?
I am not to familiar with Mercedes as this is the first one I have owned. I rebuilt it from an accident, so I didn't get the chance to check the order box for the active safety features.
My vehicle is a 2013 and has the lane keep assist, (vibrates steering wheel when over line), blind spot warning (lights in the mirrors), and the parktronic sensor (auto parking option beeps when backing up to close). Any help and info is appreciated.
Also did you have to go to the dealer do scan coding? Or were you able to do it all with vediamo? Thanks!
Old Nov 30, 2019 | 04:47 PM
  #96
guti's Avatar
My problem has been that the vehicle had no blind spot detection. If your car has it, you will have no problem.
Old Dec 17, 2019 | 08:17 AM
  #97
jrsmith_68's Avatar
Veteran: Army
After you finish the conversion you will indeed have all of the safety features as if it had Distronic Plus from the factory. One thing to say after helping others with Distronic conversions and reading about others' attempts, is that the dealer will provide ZERO assistance. The only way you can be successful with this conversion is to use Vediamo and you must be comfortable with changing the coding of several modules including the EIS.
Old Dec 17, 2019 | 08:51 AM
  #98
guti's Avatar
It is better to do everything with vediamo. If the dealer puts the chassis number and does not want to collaborate, it is more difficult. But a good dealer can do it too.
Old Jan 16, 2020 | 02:50 AM
  #99
stuparu.ionut81's Avatar
ML 350/ W166
Hi. I want to install Distronic Plus. I have almost everything. Can you please help me with the coding after the installation
Old Apr 20, 2020 | 03:10 AM
  #100
metkhoo's Avatar
ML350
"Everything I need"
When you say "I have everything". It seems very much on where you start - what options you have from the factory.
From my research, if your car has Lane Keeping Assist and Blind Spot Assist already then you are likely to be successful. If you car does not have that feature then it will be more difficult and you will need additional components... Also you are highly advised to get a STAR C4 multiplexor and a HDD with Xentry and Vadimao software as part of the "everything" you need.
/Marcus
