Cornering lights revisted....
Old Feb 1, 2013 | 10:52 PM
roger23's Avatar
Registered User
2010 E550 / 2012 ML 550
I have GLK loaner driving, while my 2012 ML550 is being serviced....
Guess what ?
It has dedicated cornering lights that work, when turning a corner with the turn signal lever on...
All ML's (2012 and 2013) do not have this feature, (even with bi xenons) although the manual says it supposed to....
Whats up with that ?
No one on this board can seem to get a straight answer from anyone at MBUSA, or MB Canada why it was deleted from the ML's....
Old Feb 1, 2013 | 11:41 PM
iankayem's Avatar
X350d GLE500e 2017, ML350 BlueTec 2012(sold), A200 2013, ML350CDI 2009(sold), Aston Martin DB7 2003
Being from down south I do actually have the active cornering lights.
But from tests in the garage, I cannot say there is any steering linked movement in the headlamps as described in the manual as "Active Light Function".
Is this only supplied on cars without cornering lights, or is the movement very minor or speed related?
Old Feb 2, 2013 | 01:46 AM
ciparis's Avatar
2016 GL 450
Ian, you won't see the motion while parked, except when you first start your vehicle (you should see the lights sweep up then sideways and back, if you can see where the light falls). You need to be in motion before they start to move when driving.
When you're on the road, you should see the light cone in front of your car move as you enter turns (highway off-ramps, for example).
ciparis's Avatar
2016 GL 450
Guess what ?
My 2011 E350 had it, as well. I'm more interested in fixing it than figuring out why we didn't get them, though
Old Feb 2, 2013 | 04:33 AM
MLee's Avatar
ML350 BT soon......pleeeease. GOT IT NOW....Wooooo
Also down under......had BMW with active lights and thought they were great. I am absolutely gob smacked at how good the ML active lights are ........ 10 times better than my much loved BMW lights. They show so much to the sides when cornering, that you can see what you have already gone past........!
at night is fun again.
