Part number for W166 AMG Pedal Covers?
Old Mar 5, 2013 | 12:42 AM
Masterbuyer's Avatar
2013 ML550 Paladium Silver/Brown Satin Ash
Could anyone please tell me what the OEM part numbers are for the Mercedes AMG Aluminum accelerator and brake Pedals that would fit the W166? Like the ones in the photo, below. Thanks!
Attached Thumbnails Part number for W166 AMG Pedal Covers?-kgrhqqokiye1flj12ytbnpjsevtc-_12.jpg
Old Mar 5, 2013 | 12:49 AM
jellies's Avatar
ML350
A1662902601
I think.
Old Mar 5, 2013 | 11:52 AM
Originally Posted by jellies
A1662902601
I think.
Thanks, but it's weird... a google search on that only brings up German and Russian MB parts websites. That is also the part number as listed in the German version of the accessories catalog (attached...and it's amazing how many accessories there are available for the M-class that aren't listed in the US version of the accessories catalog).
Does anyone know if there is a US version of this part number?
Old Mar 5, 2013 | 02:55 PM
Okay, I've been doing some online detective work. It seems that the Mercedes AMG Aluminum Pedals for the W166 are the same as for the W164 X164 X166 and W251. I guess they didn't change pedal design for for the W166.
If that's the case, then these should be the part numbers:
accel pedal: 164 300 00 82
brake pedal: 170 290 01 82
And this website I just discovered is great, as it shows which models it works with, plus little diagrams to confirm its the right part: http://www.mbpartsworld.com
www.getmercedesparts.com seems to have the best price, but they don't tell you want the shipping is going to be before you submit your order. Plus they add a $2.00 'handling charge.' So forget them! What good are low prices when you jack up everything else?
These guys are a little more, http://www.mercedespartscenter.com, but at least I know what it cost before I submit my order. They are also closer to So Cal, so I might save a buck or two on shipping anyway.
Old Apr 2, 2013 | 04:07 AM
wally AMG's Avatar
MB
check http://www.ebay.com/itm/Mercedes-Benz-AMG-Genuine-Aluminum-Pedals-Pads-W164-W166-ML350-ML450-ML500-ML63-/121033759363?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item1c2e2c9a83
Old Apr 2, 2013 | 05:46 AM
27T's Avatar
27T
13ML BT
I got mine from this guy for $80 shipped within US: http://www.ebay.com/itm/Genuine-Mercedes-AMG-Aluminum-Pedals-for-W164-X164-W166-X166-W251-GL-ML-R-/190817574085?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c6d9d1cc5&vxp=mtr
Old Apr 2, 2013 | 05:51 AM
27T's Avatar
27T
13ML BT
Something I learned was that the ML does not come with any type of gas pedal cover from factory. I checked a few other makes and they didn't either. All did come with a rubber brake pedal cover.
Old Apr 5, 2013 | 08:50 PM
bliss1's Avatar
2013 GLK; 2012 Ml350
It looks like the OEM set from http://www.mercedespartscenter.com is slightly cheaper than the ebay offerings referenced above.
Ordering a set. Thanks Masterbuyer
Old Jun 17, 2013 | 04:35 PM
marvron26's Avatar
ML350 4MATIC MY13 DIAMOND WHITE
Does anyone have an installation guide to these pedals? I'm ordering a set but don't know what type of installation is needed.
Old Jun 17, 2013 | 05:45 PM
another_geek's Avatar
'16 Jaguar F-Type R, '21 GLE63s
Installation is just slip on. I put these on on my old w164 so it's been a while, but if I recall, the gas pedal cover slips over the existing pedal. The old brake pedal cover needs to be removed and replaced with the new cover. (or maybe it's the other way around...)
No tools are needed, other than maybe pliers to help remove the old cover - just a lot of patience because the fit is very tight.
Old Jan 1, 2014 | 04:47 PM
DR2000's Avatar
2014 ML350 BlueTEC
I realize this is an older thread, but I have a silly question:
The gas pedal cover has a rubber lip on the back on 3 sides. One does not have such lip. Does the "lipless" side go on the top or on the bottom of the pedal?
Old Jan 1, 2014 | 07:16 PM
Chasvs's Avatar
ML350 Bluetec
I'm pretty sure there are lips on all sides. At least that's what I remember when I installed a set on my ML350 last month. If not on yours, I'd put the open end on the bottom. If it was on top, the slight chance of slipping down would exist. But I'd double check for lips on all sides.
Old Jan 1, 2014 | 07:20 PM
DR2000's Avatar
2014 ML350 BlueTEC
I probably didn't word it well. There is a 90 degree lip on 3 sides (it goes away from the pedal and then at 90 degree inwards). On one side it just goes away from the pedal and doesn't bend inwards after.
Would be great if somebody with AMG or sports interior could check how it is installed.
Old Jan 1, 2014 | 08:13 PM
Chasvs's Avatar
ML350 Bluetec
Originally Posted by 27T
These are what I bought as well. OEM and fit perfectly!
Old Jan 6, 2014 | 01:39 PM
DR2000's Avatar
2014 ML350 BlueTEC
Here is a pair of pictures of before and after.
Still would love to get an answer on which side goes up. More and more I think about it the lipped part should probably go on the bottom, so it doesn't accidentally gets taken off with a shoe going under it, but I'm still not sure.
Attached Thumbnails Part number for W166 AMG Pedal Covers?-zfx_4080.jpg   Part number for W166 AMG Pedal Covers?-zfx_4082.jpg
Old Jan 6, 2014 | 07:06 PM
fabbrisd1's Avatar
A gaggle of MB's
Gas - bottom of the pedal - kindof funny some people here pay more to eBay than the same parts would be from your local dealer m- each to their own - the correct parts listed under E-Class
Old Jan 6, 2014 | 07:20 PM
DR2000's Avatar
2014 ML350 BlueTEC
Bottom of the pedal should be the one with L looking lip or I looking one?
Three sides have L, one side has I. Where does I go -- top or bottom?
Thanks again.
Old Jul 8, 2014 | 11:02 AM
2014CL600's Avatar
Cars
They do not sell the S and CL pedal without the entire unit. I bought a w203 pedal off ebay for 34.00 and removed the pedal pad and swapped them without touching my original electronics. Its the only way you can do it as these models are attached to the unit and to the floor and not the types that hang.
Old Jul 8, 2014 | 01:23 PM
27T's Avatar
27T
13ML BT
Since you're so smart how much do they cost at the dealer?
Old Jul 8, 2014 | 01:51 PM
2014CL600's Avatar
Cars
I am not "So smart", I am well educated and I have access to the MBZ parts catalogs and prices. VIPGERMAN.COM sells the gas pedal P# 2213000204 for 236.00 your cost on line 169.20. Not serviced as a cover like the brake pad . P# 2302900082 price is 32.50 selling for 23.40 (but they just said not avail.) that is because the price has doubled but if you buy it from them they legally must sell it to you for the price listed. Now, if you go on Ebay and find a gas pedal assembly from any car that looks like yours (which is a double row of ovals.) You will find perfectly good used ones that you can remove the pedal cover without removing the pedal from the car. They are only held in with plastic clips. I bought mine for 34.00 (the full assembly) off of a model W209. It was a flawless piece and changed out in an about 20 minutes.
Old Jul 9, 2014 | 02:49 AM
fabbrisd1's Avatar
A gaggle of MB's
Well... if you don't have time to make a phone call
For those that seem not to have time to make a phone call to a their local MB dealer - see attached pdf with MB part#'s and MB MSRP
File Type: pdf
Old Jul 9, 2014 | 06:24 AM
2014CL600's Avatar
Cars
ML's use different pedals all together than the one the man with the S class was talking about. You cant not compare and apple to an orange.
Old Jul 9, 2014 | 10:08 PM
DFW01E55's Avatar
'14 ML BT
Thanks for the clarity fabbrisd1.
Old Jul 10, 2014 | 03:52 AM
27T's Avatar
27T
13ML BT
Ebay is cheaper. $75 shipped. No driving to dealer, delivered to your door.
http://www.ebay.com/itm/Mercedes-Benz-AMG-Genuine-Pedals-Pads-W166-ML350-ML500-ML63-13-14-2013-2014-/121160257972?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c35b6d1b4&vxp=mtr
