Driver Assistance
Old Mar 11, 2013 | 11:39 PM
EagleJBW's Avatar
ML-350
Driver Assistance
First M-B, trying to figure everything out. The "coffee cup": What's the difference between "standard" and "adaptive"?
Old Mar 12, 2013 | 12:39 AM
fabbrisd1's Avatar
A gaggle of MB's
Download the pdf copy of the Owners Manual from mbusa.com Owners Support section...
Old Mar 12, 2013 | 09:14 AM
jellies's Avatar
ML350
reading the manual several times is certainly recommended.
but I believe the "adaptive" vs "standard" is for lane keeping assist not attention assist, which is just on, or can be turned off (for good).
Adaptive: tries to reduce the number of vibration alerts that may be incorrectly triggered from spirited driving such as hard acceleration and braking, swerving, cutting sharp corners
Standard: alerts (vibrates) more often, basically every time you drift over what it thinks are lane markings without indicating.
In both cases if you continue to drift or don't correct, the car will then lightly apply the brakes on one side and a big picture of the car and a red line on the offending side lights up. This one-sided braking is not IMO effective in placing you back into lane it really just delays the drift slightly, the braking period is quite short. If you've had a heart attack, you're still gonna run off the road. The braking is more disconcerting than the vibration, though, and if you are drifting because you are distracted it certainly can't be ignored. The vibration is really very slight.
In 2000kms of driving I've had the vibrate warning many times, but go further to braking, only a few. I do like the feature though, I've turned off attention assist because I think the lane keeping assist will do the job (of nagging me) should I drive tired.
Old Mar 12, 2013 | 11:01 AM
EagleJBW's Avatar
ML-350
Thank you! I'm sure this is just the first of many questions. I'm having difficulty finding answers to some of them in the owner's manual.
Old Mar 12, 2013 | 11:14 AM
EagleJBW's Avatar
ML-350
My "coffee cup" symbol is just the cup . . . no steam coming off the top. Does that mean it has been deactivated or isn't working?
Old Mar 12, 2013 | 02:53 PM
jellies's Avatar
ML350
attention assist off gets rid of the coffee icon
it steams when the car thinks you need a rest.
otherwise it just is an empty cup to remind you of your addiction to caffeine...
Old Mar 12, 2013 | 03:02 PM
EagleJBW's Avatar
ML-350
Got it, and THANKS! That's a lot easier to understand than what I read in the manual!!
