Making a weird noise on startup. Please help!
#101
2014 Mercedes ML550 Previous Cars: 2012 CLS550 4MATIC, 2011 C63 AMG and 2009 C300 4MATIC
You are totally welcome!
Yep, the service manager at my dealership was quite amazed that I was able to locate this information but they weren't, and surely felt like a bit of a fool after telling me for a couple of months that it's normal and not to worry about it.
Had couple of other minor issues addressed as well, now she's tip top.
Thanks for your help guys!
#103
Get if fixed if it's under warranty, otherwise it can still be fixed but you'll have to pay for it I guess. MB should actually fix it out of warranty for free though. It seems a pretty common issue with alot of their engines.
#104
Excellent, glad you got it sorted!!
#105
I believe there are some Bluetecs affected by this. Spend the 5-10 minutes and read back through this thread and maybe contact one of the members who has a Bluetec. Cheers
#106
Thank you I have the same issue. I am going to take my ML to the dealrship. What is the ramification to the engine if it is not repaired quickly? I just dont want to damage the engine. Thanks
#107
Bad Piston----I took my 2012 ML 350 to the dealership for this repair. They agreed to repair it because I took the above PDF file with me. It has been in the shop for a 2 weeks due to parts not being ordered. They just call me stating they need to order more parts due to a bad Piston as well. they took the engine out now and ordering more parts. Does anybody heard of a bad piston due to this issue?
#108
i didnt sow this topic, open mine. Have less then 1000 miles on my ml350 v6, sound like disel on idle speed(ratteling) above 1000rpm sound gone, so thinking this is normal but now I see this is common problem, will provide video in next days and on youtube also, really dissapointed with top quality motors))) BS for now
#109
#110
mb Techman- Thank you for your reply. The truck still in the shop since Jan 2nd. Is there a way you can share the second bulletin. I am curious why it is taking so long for the reapir. Since they took the Engine apart do you think there are ramification from the repair side or this is a normal. Should I start looking into replacing my truck or this is not a big deal. I am affraid when the engine opened there will be more issue in the future. You recommendation or the community are welcomed.
#111
2013 ML350
Engine tensioner oil pressure - ticking noise on warm start up
Does anybody still have the service bulletin for the chain tensioners losing oil pressure when the engine is off? I want to pass to service dept when I bring in the ML. Thanks for your help.
#112
Yes, look at my post from 1 Nov '14 earlier in this tread and you'll find it there. Good luck!
#113
I am bringing up this not so old thread. Is the startup noise affect 14-15 ML350 and 14-15 GLK350? I think I have the noise but or maybe not as I know DI engines sounds a little louder than the old V6s. I am not paying too much attention about it as the two SUVs are being driven by the wife and she is deaf on any car noise.
#114
1 Post
2013 Mercedes Bezn GLK350
#115
Just to add - I got my ML550 startup noise fixed really easily by the dealer because of this thread, my noises started when the car was still new, probably around 500 miles or so.
I took a video of it starting up (one could clearly hear the metallic chattering for a few seconds), and gave them the service bulletin number as well. Service advisor was happy to get all the details and pass them on to the techs who worked on my car.
Took two days (had to order parts) but haven't heard any noises since.
So thanks to all who posted the info!
#116
engine start make a funny noise
There is nothing to worrie about it.
when you turn the engine off the oil will go all at the bottom of the engine leaving the upper part of the chain inside the engine dry. When you start your engine It takes exactly 2-3 seconds for the chain to be lubrificated all again and assume regular work.
hope this was helpful.
#117
#118
So my 2013 GLK350 with the V6 M276 engine had this sound when I got it. Just as I was getting around to fixing it, the noise disappeared. hmmmmm......
#121
I didn't read through this entire thread, the OP was years ago, but, if it helps, this sure sounds like the timing chain tensioner issue I just had resolved under warranty.
#124
Same rattling sound for 2013-ML350 BLUETEC(DIESEL)
Hi everybody,Thank you to all users active on this forum with such important informations...I read all the topic of rattling sound on startup engine ,Sorry for my bad english...I am from Romania and just bought a few weeks ago this car.It appear that i have the same exact noise like gas engines...It is the same ISSSUE like benzin cars? What should i do? My car has 165.000 KM.
thanks!
thanks!
#125
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
If you read the posts in this thread, you will come to the conclusion that you'll need to replace the cam chain tensioners and more importantly, have check valves installed on the circuits feeding the tensioners. These tensioners are hydraulically-operated. When the engine is shut off, the circuits lose pressure. It takes a few seconds after re-starting the engine before the tensioners pump up again, hence the clatter.
dgolea (04-21-2020)
