Making a weird noise on startup. Please help!
Old Apr 21, 2020 | 08:38 PM
  #126
dgolea's Avatar
ML-350 Bluetec 4Matic
Originally Posted by peter2772000
If you read the posts in this thread, you will come to the conclusion that you'll need to replace the cam chain tensioners and more importantly, have check valves installed on the circuits feeding the tensioners. These tensioners are hydraulically-operated. When the engine is shut off, the circuits lose pressure. It takes a few seconds after re-starting the engine before the tensioners pump up again, hence the clatter.
ok Peter,Thank you for clarifing..my only concern was that if is the same situation for DIESEL -Bluetec engines..Tomorrow i will go to my mechanic and will tell him.Thank you for answering!🙏🏻
Old Apr 22, 2020 | 08:14 AM
  #127
dgolea's Avatar
Can help me someone please if this is the look of chain tensioner?(picture attached) Also please help me to identify the Valves...any part# to get a ideea...Thank you!
Old Dec 10, 2021 | 11:52 PM
  #128
Mercedes guy's Avatar
2013 ML350
Flipping noise when starting
I have the same problem with my 2013 ML350 and I talked to my buddy , he’s a Mercedes’ mechanic working for The dealer so he told me it’s the timing chain . Basically it’s the chain inside the engine that needs to
be replaced . That chain runs the whole engine. I hope that helped
Old Oct 15, 2024 | 07:28 AM
  #129
TsmithJ's Avatar
Help me if you have found any solution(link not working)
Hello, Im new here.
was the problem resolved? If so, can someone send me info so that I can possibly get mine fixed as well. I have a ML350 2014 with the same noise at start up that is mentioned within this thread. Please help. Thank you
Old Oct 16, 2024 | 11:07 AM
  #130
TsmithJ's Avatar
Did the noise ever return?
[QUOTE=sparky123;6244379]Well, it's fixed now and sounding so much better on start up. My dealer knew about the service bulliten and fixed it without batting an eye...whew!
Had couple of other minor issues addressed as well, now she's tip top.
Did the noise ever return after fixing said issues. Ive had my ML for a year and this noise is about to drive me nuts. Please reply if you see this comment.
