Sirius Question
Old Dec 6, 2013 | 06:58 PM
MBduck's Avatar
2014 ML350 BlueTec
Sirius Question
OK, I have figured out all the various systems on our 2014 ML except one. It regards changing channels on Sirius. Let's say I am listening to channel 22 in the category "Rock" and I want to change to channel 17 which happens to be in Category "Pop." (I may have the categories wrong but let them serve as examples) If I want to go from 22 to 17 I can't use the Command dial as it simply cycles through all the "Rock" channels. I have to first select category "Pop" from the menu and then use the dial to go to channel 17. Is there a faster way to do this? Is there a way to use the dashboard keypad to enter channels? I know I must be missing something!
Old Dec 6, 2013 | 07:15 PM
fabbrisd1's Avatar
A gaggle of MB's
Use *XXX to direct enter the channel you want to move too... to put a channel in moemry press and hold keyboard key... try downloading manuals from mbusa.com
Old Jan 1, 2014 | 01:15 PM
Ensoniq's Avatar
Ml 350 4matic
http://www.mbusa.com/vcm/MB/DigitalA...14_M_Class.pdf
Link to PDF of 2014 M manual
Old Jan 1, 2014 | 02:55 PM
Pntblnk's Avatar
2017 S550 Iridium / Black Nappa, 2015 GL 550 Paladium Silver
The other simple option is to choose "all" in the category section instead of "rock" or pop" This lets' you scan the stations in numerical order with the command knob.
