New Ml550 on 22" replicas
Old Dec 17, 2013 | 09:00 PM
threeMBs's Avatar
Only MBs - the best or nothing
Originally Posted by jtorrebl
275 40 22 will increase the diameter of the wheel even more than what I got which is slightly taller than stock but not much
Increasing diameter over stock for MLs is a non-issue. They can take 2", at least. The issue is what kind of tire one uses (not the size so much) and if mounted on correct size wheel. One buys ML, I suppose, cause its the safest SUV out there. Why compromise by installing inferior (to say the least) tires. Tires are the only thing touching the ground. I want the best tires to provide the best traction in all situations (especially since wheels' construction is questionable as well). But its just me. As long as you're happy that's all that counts. I'm not really questioning your choice, I just wanted to know as many detail of what you've got since I was thinking of the same route, but putting 5K lbs SUV with incredible speeds capabilities of ML550 on inferior product is too risky for me.
Old Dec 17, 2013 | 09:07 PM
Nanook's Avatar
'18 GLE63S AMG /'19 PORSCHE TURBO S / '09 CORVETTE ZR1 /'14 LEXUS RX350/'16 RAV4 Ltd
There is very little room to go over stock 29.x inch diameter at least on front of a ML63 for risk of rubbing especially when turning...the stock size is very very close already
Old Dec 17, 2013 | 09:40 PM
Kenn1926's Avatar
2013 ML550
I had the same issue with the rear sub. I noticed the first day I had my truck. They fixed it a few days later when I brought it in to have the remote start installed. They said something was loose from the factory, I haven't had a problem since...
Old Dec 18, 2013 | 09:15 AM
threeMBs's Avatar
Well ML63 is lower and uses much wider tires (295 vs. 265/255) than ML550 and ML350. What I do know is that both ML350 and ML550 can accept GL sized diameter tires (30") with room left for more.
Old Dec 18, 2013 | 09:22 AM
Nanook's Avatar
Possibly so but I'm referring to the clearance at the front and back of the wheel/tire to fender liner..I can barely get a finger in there..possibly because I lowered it...dunno
Old Dec 18, 2013 | 10:39 AM
threeMBs's Avatar
You answered your own "question". On stock (non-lowered) ML350/550 (not 63) there's room for as much as 31" diameter tires.
