Multicontour Front Seats?
We have 2 favorites buttons on the ML, right (or did I lose one with the comfort seats button)?
Nanook I got a master vehicle vin inquiry sheet from my SA last time I was there. Thats a possible choice for you as well.
I think they mean the fav programmable buttons on console
ChrisMclass, you do seem to have the above combination. What is your opinion?
I think you are referring to the seat memory ... you are correct there are three memory buttons for seats that have the memory option.
I was asking about the "favorites" button that allows direct access to a specific function in the COMMAND system.
Those ridiculous running boards sure do get in the way though.
I believe the differences between the standard and "multi-contour" seats on the regular ML are:
- massage function (accessed via COMAND)
- several additional adjustments (tighten side bolsters, tighten seat-bottom bolsters, extend seat-bottom) again, all accessed via COMAND
- Ability to adjust the way the heating function is balanced (between the seat-bottom and the back)
The ventilated seat feature is a separate option (that requires leather). There are no additional adjustments to the ventilation when the "multi-contour" seats are purchased.
Last edited by mellow sparky; Jan 18, 2014 at 03:28 PM. Reason: forgot to add some info
