Pothole, now need new tires ;(
Okay, hit a big pothole this afternoon and immediately my tire pressure monitor went off. Now I have to replace both front tires.
What do you guys recommend for All Season 265/45/20? |
Since you are replacing two - and not four - your ONLY option is to replace with same brand/series as on the rear.... tge good thing is you should get Road Hazard for the replacement tire ... if you had had Mercedes wheel/tire all this would have been taken care of under that coverage...
Got the car pre-owned and I don't think the previous owner has any tire/wheel warranty on it. I'm going to discount tires tomorrow to pick up a pair... why do I have to get the same brand as the rear? Is this something unique to Mercedes? All my previous cars I was able to order different, I will eventually replace the back 2 as well.
At the very least you want to keep the 2 tires on the same "axle" the same exact tire as each other to retain as much of the handling characteristics as the car is supposed to have.
For it to be the most stable & predictable, all 4 should be the same tread design/manufacturer/style. It is NOT unique to MB, but to all vehicles. |
another thing to check is the tire wear on the rear wheels. If you dont have that much thread remaining, the diameter is slightly smaller than bran new tires. On a 4WD, that means the center differential will be constantly spinning to compensate for the difference in wheel speeds. Differentials are not made for that and this can lead to premature failure.
Originally Posted by eggyacid
(Post 6174715)
Originally Posted by Baloo588
(Post 6174928)
Thats a big mistake. You should never replace 2 sets of tires from different brand and type then the ones you have on the rear. It causes extreme stress on the 4WD transfer case when you have 2 different front tires and 2 different rear tires. Also, you cannot have tires on the front more then 2/32 inch difference or the rolling resistance will hurt the transmission when the wheels are rotating at different speeds.
Originally Posted by jchochla
(Post 6174989)
I agree. If you own a mercedes, you should be aware of the tires and maintenance costs. You need to have all 4 tires the same. If you don't, you will mess up for 4matic.
