lights out on both front doors
Old Jan 26, 2015 | 11:07 PM
foolesh's Avatar
2013 ML350 4MATIC
Smile lights out on both front doors
anybody knows which fuse to check and replace and how?
both rear door lights work fine, so I suspect it is likely fuse, much less likely both front bulbs were burnt.
I might not be clear enough - two front courtesy lights won't come on when door is open.
Old Jan 27, 2015 | 06:52 AM
DUTCH's Avatar
2000 MB G500 NMLE, 2015 Audi Q7 3.0 TDI Prestige
Courtesy lights? The ones above the rear view mirror? There is a three way switch up there that controls the courtesy lights. On - On when Door Open - Off. Check to see if it's in the Off position. Flip the switch between the three positions to be sure that the contacts are making and breaking.
If it''s a fuse, it should be located in the fuse block located under the right rear seat. Inside the covered block there should be a folded piece of paper that describes which fuse protects what.
