ML 350 Bluetec W166 vibration during drive between 65-85 miles
Hello everybody!
I have a problem with me car I feel some vibration during drive between 65-85 miles. I bought me car with original 21 Zoll wheels (AMG) there I had every time when I was driving strong vibration. It was so hard that you cann see how your cockpit i shaking. I thought that me 21 Zoll wheels has a Problem. Thatīs why i wait till I wear the 19 zoll wheels for the winter. Same issue but not so strong vibrations as with 21 zoll wheels. I went severral times to MB for service. Nothing can be found they told me everytime that me wheels are wrong weighed heavy. I went with all me wheels to a Bosch service to confirm that me wheels are really bad. But they could not found anything, everything is ok! I asked also in a german forum and there i found two guys that they have the same problem but without any solution. Is also somebody there who has the same problems? Or know something about that issue? Thank you and greeting from Stuttgart!!! |
That really looks like a balancing issue... If the wheels are indeed perfect, then I would look at the brake rotors... Although I have never seen a rotor badly balanced. Good luck and keep us informed!
Many Mercedes dealers in the States use Hunter Road Force machines that can analyze wheel balance, runout and other aspects under variable simulated road and speed conditions. I'm sure Germany must have equivalent equipment. If your wheels check out OK, I suppose you would have to look elsewhere for the problem.
Also, there was a case several years ago in which either the studs or the mounting holes in a wheel were off. Can't remember which. The wheels checked out fine when dismounted but vibrated when mounted on the vehicle, which was a Mercedes, though I don't recall the model. |
Hi,
I found a solution for the vibration during drive. They chanced the wheels and wirh me 21 zoll amg rims me car is not vibrating any more ;-) Now we will see what kind of problem if have also with we winter wheels... But till that we have a few months ;-) |
2014 ML 350 Bluetec
I am having a problem of vibration at 55mph to 65 mph also. The vehicle has been to the dealership 3 times and they cannot resolve the issue. We hope that M Benz will fix the problem under warranty. Will keep you posted on any progess.
I had a similar experience with vibration at speed (but not with an MB), felt like an unbalanced wheel. Spent a lot of time, many visits, at a dealer, who had no clue. Finally went to a proper tire dealer, and he found the problem in minutes!!! Steel Belts inside 2 of 4 tires(Goodyear Eagles) had 'moved'. The dealer had balanced the tire multiple times to no avail.... as the steel belts within the tire would move, and then create another unbalanced/ vibration situation at speed. To those having problems with a vibration at speed... hoist up the car, and spin each tire by hand, while looking closely at the center tread line. Any deviation in the tracking, you will most likely have a belt that is 'loose' or 'broken'. Was a PITA until diagnosed properly... good luck!
Hello Everyone
Newbie here .I had the same issue with my ML550 .Took it to the dealer and they said it was my two front rotor disc were warped so in over all they want me to replace them . Off topic any advise of what rotor disc to go with |
Same thing here.
I am having the exact same problem, I got my wheel balanced and rotated. Still. Help.
Originally Posted by Yash.J
(Post 8590829)
Any information will help. |
