Key FOB Not Detected
Old Apr 12, 2015 | 03:02 AM
jtorrebl's Avatar
2025 Panamera GTS
Originally Posted by Barry45RPM
I keep the MB key with all my other keys in my Right pocket, and the Wife's BMW key in my Left pocket. (Both keys are Keyless Go type). I rarely have to jingle the MB pocket contents.
Why do you carry 2 sets of keys with you?
Old Apr 12, 2015 | 04:12 PM
B5chung's Avatar
2015 E250 Bluetec
According to MB service advisor the key fob works on RF if any cell service nearby will affect the operation. It happens to both of my cars, it's really annoyed, intermittent problem that we're having its very difficult to troubleshoot, I hope they can update the firmware to make it less sensitive to other RF in the nearby area.
Old Apr 12, 2015 | 04:15 PM
PeterUbers's Avatar
The proximity key and keyless go in my Acura and Infiniti are flawless ... And about 90% in the Benz
Old Apr 23, 2015 | 12:55 PM
EDC320's Avatar
2015 ML350 4Matic
Keep key in cup holder with nothing near it and having issues.
At parking lot, with key in cup holder, car would start with keyless go and then turn off immediately. Tried this 4 times and finally gave up and pulled the start button.
Put the button back in and tried using keyless go, while it appeared to work, when driving the car, the key fob not detected started flashing and would not stop so I pulled the start button and use the key conventionally.
Car is 4 months old with 4,700 miles. This is so pathetic.
Old Apr 23, 2015 | 01:18 PM
gvernt_2000's Avatar
bmw530
Update
Last Thursday one of of two tests where the car was left alone for 4 days. Anyway, I turned off the IP camera which is about 3 feet away and didn't bring my smart phone into the car during the start. Guess what it actually started using the button, so tonight I'm going to repeat the same test again. The vehicle has been sitting in the garage since Sunday night. Lets' see if its going to start tonight...
Old Apr 23, 2015 | 07:49 PM
Subatomic Power's Avatar
GLE63S 2016
That is pretty bad. But it sounds like a warrantee issue. I'd take it to the dealer to get sorted out. Either the fob transmitter is buggered, or the receiver is buggered. But it's something......good luck!
Old Jan 1, 2016 | 12:07 PM
  #32
Binxxxx's Avatar
2004 c240 4matic, 2005 CLK500 cabriolet, 2010 E350 4matic (previously owned 2003 SLK32 AMG)
If you have NOT replaced your battery...
For newbies (like me), the very first thing you need to try if you are getting the "key not detected" message is to TEST your battery in your key(s).
You can easily do this by pressing one of the buttons. You should see a small red LED flash near the top of the key. If you do not see a red light, replace the battery, even if you replaced it yesterday.
Batteries can be old / weak and only work for a short time "out of the box". I bought CR2025 Lithium batteries on eBay for very cheap (10 for $5.34 US)... and you get what you pay for (3 months of use).
For those of you who have already don this, I found interesting information posted on justanswer.com, provided by a self-proclaimed UK MB Tech with 20+ years in the business. The issue inquiry was for an E350 with ignition failure and the gist of the information is this:
There are several points of failure on the car for this problem - the key sends a signal to the EIS (electronic ignition switch), if the EIS detects the correct key then it sends a signal to the ESL (electronic steering lock) to unlock the steering, once unlocked it sends a signal back to the EIS to allow the key to turn & the engine to start.
So in theory it could be the key, the EIS or the ESL.
Key failure is a common problem & it is wise to get a replacement key to rule out any key problems - batteries are only needed for the remote central locking & not needed once the key is inserted in the ignition to turn the key, so batteries would not be an issue.
The main vehicle battery should also be checked to ensure it is in good order - if the battery is flat then recheck after you have finished charging it.
The key is the most common failure, followed by the EIS & the ESL being the least problematic of them all.
Read more: http://www.justanswer.com/mercedes/7...#ixzz3w0s2YSuh
Hope this information is helpful.
Old Jan 1, 2016 | 12:33 PM
  #33
shortspark's Avatar
2017 CLS550
Excellent information!
Old Jan 1, 2016 | 07:48 PM
  #34
GLE63S 2016
Very Helpful! Thank-you! I have discovered that the battery only lasts about 6-8 weeks in the key fob. It is incredibly irritating to have to change it all the time, and it is the biggest gripe they hear at the dealership. Most dealerships will change the battery for free with no issues, but I have discovered that buying a bag of batteries from Batteryjunction.com is the best thing to do. I keep a few extras in each of my vehicles and garages now.
Old Jan 1, 2016 | 08:18 PM
  #35
fabbrisd1's Avatar
A gaggle of MB's
To our Canadian friend - let me give you accurate info - because frankly with the correct/best CR2025 fob battery you will have well over 1yr battery life - and many of my customers are getting 2yrs+.
The correct/best CR2025 battery for your fob is Maxell/Japan - which is the only CR2025 made in Japan - and is identifiable by it's hologram printed blister pack - in Canada a 5-pack is under CDN$5:
MAXELL 5 Pcs CR2025 CR 2025 - 3V Lithium Button Cell Battery Batteries - NEW: Amazon.ca: Health & Personal Care MAXELL 5 Pcs CR2025 CR 2025 - 3V Lithium Button Cell Battery Batteries - NEW: Amazon.ca: Health & Personal Care
Unfortunately in the CR2025 "retail" - believe it or not - their is a HUGE counterfeiting and product misrepresentation - not only for the correct/best CR2025 - which is why I reference the correct/ONLY genuine hologram package - but for CR2025's it is common to have cheaper alkaline cells marked/sold as lithium - and a whole sh*t storm of poor China/non-Japan batteries
The fob batteries with Mercedes new car production - and at US Mercedes dealers - at $1.60 dealer cost is a Panasonic brand battery - and unfortunately 4-5 yrs ago Panasonic battery production was moved from Japan to Indonesia - the specs for that Indonesia battery are "the same" - but yes - 6 mo useful is all-to-common - like a 6 mo egg timer counting down.
Get the right battery - genuine Maxell CR2025 in correct hologram package - here in the US eBay becomes best at about USD$.50-$.60 each - production stamped in black# on cell face) battery code "51" - means manuf 2015 in January - which right now is "current fresh" inventory - no worries 95% shelf life genuine Maxell CR2025 is 5 yrs.
Old Jan 1, 2016 | 11:07 PM
  #36
EDC320's Avatar
2015 ML350 4Matic
Not a battery issue problem with keyless go
Happened again today. Keyless go did not detect key. Problem was smart phone laying in center console while key in pocket.
After several attempts out phone in left jacket pocket and key in right jacket poclet and miraculously the key was detected.
Car drives like a mb should but these electrical glitches are unacceptable for a premium product.
