MY16 GLE Dealer Ordering Guide (DOG) 2 pages
I have seen the Dealer Ordering Guide for the 2016 GLE, and am attaching two of the most important pages. The rest of it is mostly photos of the GLE including exterior, interior and a lot of upholstery. It is the very first version of the DOG; no prices are given except to compare 2015 P01 and 2016 P01.
I don't see airmatic as a stand-alone option.
The mbusa.com web site indicates that the "Dynamic Select" option is NOT available on the diesel model, and the DOG doesn't mention dynamic select at all.
The bulk of information in the DOG is the same as the information in the GLE press release on mbusa.com.
I got a look at the 2016 DOG and saw a couple of oddities...
1. GLE300d - one page shows pictures of the wheels and lists 18" R41 as standard. But, a few pages later on a specification page it lists the standard size for front and rear wheels as 7.5J x 17. I would assume 18" is standard as in 2015 but ....
2. The 2016 DOG lists option #401 as Heated/Ventilated seats but the 2015 DOG lists the #401 option as Ventilated seats (does not say Heated). Puts a little doubt in my mind whether heated front seats are std in 2016.
Disclaimer - I've just started researching the ML/GLE as my wife wants to replace her 335Xi with an SUV so she can haul the grandkids easier (and get a better quality ride); not knowledgeable on the MB's, just trying to get info and get up to speed.
LSU - good points and pickup on the DOG - from my side I will do some checking from my end.
Please note on the 300D - from what I have seen in the past - if August production - retail delivery may be a bit delayed since this new production diesel model will need to secure Federal approval - which will be no problem - but the ways the Feds set that up - production/line vehicle has to be submitted - and Fed approval process may take initial delivery out a few weeks - meaning initial production will be built and held at VPC until Fed's say "yes".
Based on W166 GLE:
1. Tire size - I believe your saleperson could go into Build-Config tool in Netstar - and a build sheet would clarify this conflict . Next release of dealer order guide should clarify.
2. Ventilated Seats - I believe Heated Seats will be included in std features - and that "heated/ventilated" language is common MB speak - since you are not familar with ML's - ventilated option is for leather interior front seats - not avail/used for MB Tex - gratefully my customers experience MB Tex as a material does not get "scalding sun hot" like leather can.
Keep the beat !
Based on W166 GLE:
Keep the beat !
The 1st Release of the Dealer Order Guide - generally gets amended/updated 2-3 times between now and Sept - the updates reflect clarifying spec points like those that have been brought up here.
The Dealer Config NetStar tool - right now is also a bit buggy - and that gets refined/updated as well as the system updates over the next few weeks for production.
1) yes - GLE base specs incl heated seats
2) Base Specs - also incl Keyless Start (Start Button) not to be confused with Keyless Go/lock-unlock) - a interesting new build feature called Mirror Projector Logo - and
the base steering wheel also calls out Nappa leather Steering Wheel
2) yes - base tires/wheels for GLE300D will be the 10-spoke 18's
The "300D" as far as I am aware will be a updated/refined version of the 250...
Fab -
Thanks for the help & info. The order is in Netstar now, though dealer says its too early to print a build sheet. Status is A4 ... I think we can make changes until it hits B3?
Yes - you cam make changes up to about 5 weeks before build date - A4 is pending order - too early yet for factory to confirm back accepting the spec - should be cleared/ accepted in about 2 weeks my estimate
2016 GLE300d-4M (diesel 4MATIC) — $52,500
2016 GLE350-4M (gasoline 4MATIC) — $53,600
2016 GLE350 (gasoline RWD) — $51,100
2016 GLE400-4M (twin-turbo V6 gasoline 4MATIC) — $64,600
2016 GLE63 AMG (twin-turbo V8 gasoline) — $99,950
2016 GLE63 S AMG (twin-turbo V8 gasoline; more power than the regular AMG) — $107,100
2016 GLE450C Coupe (twin-turbo V6 gasoline 4MATIC) — $65,100
2016 GLE63 AMG Coupe (twin-turbo V8 gasoline 4MATIC) — $109,300
The only one I don't have right this second handy is the 2016 GLE550e-4M (plug-in hybrid)
