Factory ball mount (drawbar)?
Old Apr 29, 2015 | 08:25 AM
gkgeiger's Avatar
'10 C300, '15 ML250BT, '22 M850i Vert
I found these pictures in a 2012 post about the ML towing Pkg. Does anyone know if they still furnish this with the newer ML's? I looked all around the spare tire compartment and found nothing.
Old Apr 29, 2015 | 10:36 AM
gkgeiger's Avatar
After doing some research I found out that they stopped including these in 2013. If anyone has one they are not using, I would be interested in buying it.
Old Apr 30, 2015 | 12:22 AM
rtw_travel's Avatar
2012 ML350 BT, 1998 BMW 540i/6
Wow- I had no idea there was a hitch there. Thanks for posting.
I'd like to keep mine, but this is the perfect thing to buy at an auto wrecker for $20. There must be one near you...
Old Apr 30, 2015 | 06:37 AM
gkgeiger's Avatar
I'll give you $40. No luck so far at a wrecking yard. I'm sure there are other people like you that have owned their car for 4 years and didn't know it was there. In that case they don't need it. I'll buy it and use it.
Old Apr 30, 2015 | 10:48 AM
350MH83's Avatar
2017 GLS 350d
It might sound stupid, but if a car does not have it in the trunk, are you sure you will be able to mount it on? Isnt there a special kit to have fitted on the car in order to hook that up?
Old Apr 30, 2015 | 10:57 AM
gkgeiger's Avatar
I'm not sure what you are referring to, other then my car came with the towing package. All W166 cars use the same hitch so the coupling should work.
Old Apr 30, 2015 | 11:14 AM
caf's Avatar
caf
car
My 2012 came with the ball mount. Although a nice touch in theory, it fit so loosely in the receiver that it rattled considerably. It's surprising that the one they included is such a poor fit. Now I usually use an aftermarket one I've got which fits perfectly. I'll keep the factory one as a backup, however.
Old Apr 30, 2015 | 11:15 AM
Barry45RPM's Avatar
2015 ML 350
The tow package comes with a "frame mounted" hitch assembly which that rod and ball slide & lock into. That piece in the picture doesn't connect directly to the vehicle.
When its not needed to tow, you slide it out of the part under the bumper so you can walk behind the car and not hit your shins. For example, see the following illustration (The ball has not yet been installed.): http://www.carid.com/hidden-hitch/tr...FUEV7AodqF4ASg
Old Apr 30, 2015 | 05:19 PM
skw's Avatar
skw
2019 GLS450
Same here. Mine came w/ the one pictured and I may have used it once. I still have it (as a spare) and often use the one I had from when I had my MDX.
Old Apr 30, 2015 | 05:24 PM
gkgeiger's Avatar
You sound like a candidate for selling. I have a means to keep it from rattling.
Old Apr 30, 2015 | 08:11 PM
DUTCH's Avatar
2000 MB G500 NMLE, 2015 Audi Q7 3.0 TDI Prestige
My experience with my 2014 BT was that the hitch receiver was so low that I needed a draw bar and ball with a lift rather than a drop like the one in the photo.
Old Apr 30, 2015 | 09:47 PM
gkgeiger's Avatar
All trailers are different, for my application the factory draw bar is perfect.
Old May 1, 2015 | 04:28 AM
350MH83's Avatar
2017 GLS 350d
Cant you just unscrew the ball and screw it back on the other side of the arm so that it raises instead of drops? It looks like the coupling is symmetric.
Old May 1, 2015 | 06:16 AM
MLee's Avatar
ML350 BT soon......pleeeease. GOT IT NOW....Wooooo
Mine is a 2013 and it's totally different to the OP pic.
Old May 4, 2015 | 12:26 PM
jrsmith_68's Avatar
Veteran: Army
2007 C350 2015 ML400 1968 Ford Mustang
What does yours look like? Does it have the nice styrofoam support like the one shown by the OP. That is what I am interested in.
Old May 4, 2015 | 07:44 PM
MLee's Avatar
No styrofoam. It's stored in a bag.
Old May 4, 2015 | 08:10 PM
chrislk55's Avatar
2023 GLE63S - Edition 55
Did your 2013 Hitch package include the hitch and ball? My 2015 didnt. At least I havent found it yet
Old May 4, 2015 | 08:13 PM
gkgeiger's Avatar
Post #2
Old May 4, 2015 | 08:19 PM
gkgeiger's Avatar
That thing looks weird. It came with the car, from the factory? What does the hitch look like?
Old May 4, 2015 | 08:58 PM
DUTCH's Avatar
Different countries have different hardware requirements. He is in OZ.
In Europe some cars have an electrically folding self storing hitch.
Old May 4, 2015 | 09:02 PM
gkgeiger's Avatar
Different countries have different hardware requirements. In Europe some cars have an electrically folding hitch.
Ah! Didn't notice the country.
Old May 5, 2015 | 05:51 AM
MLee's Avatar
Yep, factory supplied. Hitch receiver is a round hole with a V either side.
The knob on the right rotates to lock and unlock. It also has a key lock for total security. Has to be the easiest I've ever put in or out.
Old May 5, 2015 | 03:46 PM
gkgeiger's Avatar
Still looking to buy one like the one in my OP.
Old May 5, 2015 | 05:48 PM
Barry45RPM's Avatar
2015 ML 350
Various available drops available...
http://www.autoaccessoriesgarage.com...m-V-Ball-Mount
Old May 5, 2015 | 07:47 PM
gkgeiger's Avatar
Barry,
After over 40 years in the auto industry I know about ball mounts. What I want is what I showed in the very first post., but thanks anyway.
