airmatic function
Old Nov 2, 2015 | 12:56 AM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
airmatic function
If you have airmatic and you set it on sports then press the lift button what will you expect to happen?
would it:
a. cancel the sport setting and revert back to comfort mode but the light still be on sport mode and not in comfort mode.
b. retain the sport setting but raises the car up (does this makes sense!?). Would you feel the same ride harshness and pickup of the car when it is on the regular sport mode while the car is raised?
How much the car will raise when you are on the sport mode when you hit the raise button? Would it be the same height as comfort mode/ tad lower/ higher than comfort mode?
