Collision Warning with active braking
Old Mar 25, 2016 | 08:24 AM
The G Man's Avatar
2019 E300
The wife Just picked up a 2014 ML350, it has option 258, which is collision warning system with active braking intervention, FCW stop. The salesman told us the car will not apply the brakes automatically for us in an event of a possible collision, it seems to me the name of the option implies otherwise. Does anybody have this system and know exactly how it work, a brief description is much appreciated.
Old Mar 25, 2016 | 06:14 PM
jrsmith_68's Avatar
Veteran: Army
2007 C350 2015 ML400 1968 Ford Mustang
Dealer is correct. The FCW will warn you if you are not slowing down sufficiently. Once you tap the brake, if you are not slowing down fast enough to avoid a collision, the system takes over. That is the "active braking" function. Saved my butt a couple of times, but will also scare the crap out of you.
Old Mar 26, 2016 | 06:46 PM
The G Man's Avatar
2019 E300
Thanks jrsmith_68 for the response. Let me try to get this correct, option 258 will not apply the brakes for you unless I hit the brakes first and then the system takes over calculates the necessary brake force to stop the car safely.
Old Mar 27, 2016 | 11:37 AM
jrsmith_68's Avatar
Veteran: Army
Correct.
