Power Liftgate
Old Sep 20, 2016 | 11:15 PM
Asw19flier's Avatar
2025 GLE450
Power Liftgate
Hi,
My power liftgate motor stopped functioning... It starts and over torques (with a beep) or barely moves forward or backward. Im pretty sure it is it, since more than once Ive been forcing it in different directions. Since my car is out of warranty is it possible to replace it by my self? Found a part for $270? Or is it anything needing reprogramming etc. Any ideas, recommendations?
Old Sep 21, 2016 | 09:21 AM
MBSang's Avatar
14 ML350 4MATIC
Did you try to reset the gate? If not, I would try to reset it first. Just lift it up, and hold down the red "open/close" button on the power gate for 3-4 sec, you will hear two chimes. That will reset the gate.
Old Sep 21, 2016 | 09:53 AM
Asw19flier's Avatar
2025 GLE450
https://www.youtube.com/watch?v=F6dTrnslLSA
- Thanks for the professional help...but that video pops out first when you type in the google lifgate malfunction, any in my case it does nothing. Gate starts closing and trips out. I'd like to add that before, motor torque was much stronger, now the motor barely moves.
My vin: 4JGDA5HB0CA030952
Old Sep 21, 2016 | 09:57 AM
MBSang's Avatar
14 ML350 4MATIC
I just wanted let you know this trick may fix the tailgate issue... which I often need to do by myself when my tailgate doesn't open... I just manually open it, and reset, then it works... Good luck!
